Author Topic: Need some help!!!  (Read 846 times)
Offline flyboy1976
Need some help!!!
« on: June 06, 2013, 05:47:12 pm »
Can anyone point me in the right direct with a very persistent issue I have.
I Keep having several re-occurring fault codes on my eddy!
Have changed all the hardware on the manifold and these codes are a result of a throttle body failure that I have rectified.....im out of ideas and really need some serious help guys.
Sunday,02,June,2013,17:39:46:01199
VCDS Version: Release 11.11.5
Data version: 20121222
                Address 01: Engine       Labels: 06F-907-115-AXX.lbl
Control Module Part Number: 1K0 907 115 L    HW: 8P0 907 115 B
  Component and/or Version: 2.0l R4/4V TFSI     0030
           Software Coding: 0403000318070160
            Work Shop Code: WSC 13881 280 427526
                      VCID: 2F4B2060BE19E360886
1 Fault Found:
004248 - Intake Manifold Tuning Valve Position Sensor (G336)
               P1098 - 001 - Open or Short to Plus
             Freeze Frame:
                    Fault Status: 01100001
                    Fault Priority: 0
                    Fault Frequency: 1
                    Mileage: 59020 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 17:37:26
             Freeze Frame:
                    RPM: 5068 /min
                    Load: 83.9 %
                    Speed: 66.0 km/h
                    Temperature: 81.0°C
                    Temperature: 20.0°C
                    Absolute Pres.: 1020.0 mbar
                    Voltage: 13.970 V
Readiness: 0110 0100
Thursday,06,June,2013,11:52:04:01199
VCDS Version: Release 11.11.6
Data version: 20121223
            Work Shop Code: WSC 12597 027 468775
                      VCID: 2F4B2060BE19E360891
Fault Codes have been Erased
1 Fault Found:
001602 - Sensor Reference Voltage A: Circuit
               P0642 - 002 - Low
             Freeze Frame:
                    Fault Status: 01100010
                    Fault Priority: 0
                    Fault Frequency: 1
                    Mileage: 59342 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 11:48:46
             Freeze Frame:
                    RPM: 770 /min
                    Load: 16.5 %
                    Speed: 0.0 km/h
                    Temperature: 81.0°C
                    Temperature: 32.0°C
                    Absolute Pres.: 1010.0 mbar
                    Voltage: 13.970 V
THE LAST  FAULT CODE ABOVE APPEARED WITH A 'P3138'  intake manifold flap motor deviation.
I have VCDS and always do adaption when unplugging intake flap motor or throttle body.
Anyone?
Offline scopes
  • -Given: 131
  • -Receive: 115
  • Wolfsburg Edition
    • My GTI
Re: Need some help!!!
« Reply #1 on: June 28, 2013, 09:40:29 pm »
Hey Dude
Did you ever find out the problem, if so what was the fix?
Silver is the way !
