Author Topic: Golf GT TDI Electrical probs (Light)  (Read 3653 times)
Offline Andyf
« on: June 06, 2013, 10:00:06 pm »
Hi
I keep getting on my Cluster Right Front Parking light not working. Some times just one side some times its says both are not working. (Left and Right). Ive checked and they dont work.
The fault in intermitant, I scanned with Vagcom and
   Subsystem 1 - Part No: 1K2 955 119 E  Labels: 1KX-955-119.CLB
   Component: Wischer 110308 021  0501
   Coding: 00038805
   Shop #: WSC 01287
   Subsystem 2 - Part No: 1K0 955 559 AH  Labels: 1K0-955-559-AG.CLB
   Component: RLS     310308 054  0402
   Coding: 00209069
   Shop #: WSC 01287
2 Faults Found:
02394 - Parking Light Left Front (M1)
            012 - Electrical Fault in Circuit - Intermittent
             Freeze Frame:
                    Fault Status: 00101100
                    Fault Priority: 2
                    Fault Frequency: 2
                    Reset counter: 187
                    Mileage: 118073 km
                    Time Indication: 0
                    Date: 2005.09.13
                    Time: 31:63:63
             Freeze Frame:
                        ON
                    Voltage: 11.95 V
                        ON
                        ON
                        OFF
                        OFF
                        OFF
02395 - Parking Light Right Front (M3)
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 187
                    Mileage: 118111 km
                    Time Indication: 0
                    Date: 2005.09.13
                    Time: 31:63:63
             Freeze Frame:
                        ON
                    Voltage: 12.25 V
                        ON
                        ON
                        OFF
                        OFF
                        OFF
and
Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MIN3.lbl
   Part No SW: 1K0 959 702 M    HW: 1K0 959 702 M
   Component: Tuer-SG         006 1220
   Coding: 0000692
   Shop #: WSC 01392 785 00200
   VCID: 3979F7127075D2D0275
1 Fault Found:
00110 - Right Mirror Turn Signal Lamp (L132)
Im new to VCDS. Not really sure where to start to try and find the fault.
I was wondering if the fault was with the Electrical System Control Module J519 from what ive read.
what do you guys think? can i do any testing in VCDS
Andy
Offline GTI-Pirelli
  • -Receive: 27
Re: Golf GT TDI Electrical probs (Light)
« Reply #1 on: June 06, 2013, 10:21:51 pm »
The turn signal is possibly on its way out I am afraid.
I get that error on my driver's side one. In cold damp weather it seems to have a three stage flash. Off-1/2 bright-full bright.
It doesn't do it 95% of the time, but when it does it logs a fault exactly like yours.
It isn't doing it now - works perfectly but I know I will have to change it eventually.
I replaced my passenger side one as it got very dim. Exactly the same fault through VCDS.
The side lights could be a faulty connection or bulbs that are nearing the end of their life.
I had a similar problem with my numberplate lights. One day they just both stopped working. I checked the bulbs with a meter then lit them both with a bench power supply. Put back in the car - Don't work.
I put new bulbs in and they have been fine ever since. Still have the so-called faulty ones (couldn't bring myself to bin them as they still work).
VW have concocted a very complex bulb monitoring system the measure the current draw on the bulbs. If it dips too low (old drew less current than new ones in my case), a fault is logged. In the case of the numberplate lights - the circuit is switched off until the ignition is cycled.
Sorry for the waffle - just try changing the bulbs in the parking lights for a few £££. I am waiting for the indicator to fail as it is about £29 IRC to replace.
2017 Audi S4
Offline Andyf
« Reply #2 on: June 06, 2013, 10:31:12 pm »
OK Thanks
Worth a shot for a few quid,
Andy
Prob should of mentioned they work ok when the fault indicator is not there!.  Dont work when the fault is diplayed on the cluster. ive tried the VCDS output test when the fault is on the cluster the parking lights dont work and the VCDS reading drop very quickly to 0.
