Author Topic: finished fitting highline and wiper stalk- how do i get the wiper stalk working  (Read 8294 times)
Offline reaper7881
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,68492
hi
i just recently purchased a highline speedo, wiper stalk and 3 spoke wheel  from ebay
ive got the speedo all coded up and working nicely with the car no problems,
but how to i tell the car that it has a multi-function wiper stalk/ activate the wiper stalk in vcds
thanks :wink:
mk5 golf 1.9 tdi
« Last Edit: June 07, 2013, 10:02:13 pm by reaper7881 »
54 MK5 Golf 1.9tdi 3dr SMD Full Interior and Speedo Conversion, GTi Highline , Flat Bottom Wheel, ED30 Rear lights
Offline Andyf
Hi
What Cluster have you upgraded from?
Have you got a high line steering control module?
http://wiki.ross-tech.com/wiki/index.php/Steering_Wheel_Control_Module_Versions
i did read somewhere some high line clusters work using MFSW.
Offline reaper7881
my old cluster was a midline 1k0 920 951 g
the new highline cluster is 1K0 920 970 L
the black box under the steering wheel says
the guy i bought it off had the conversion done by some one and it worked with the wiper stalk
rosstechs website says
1K0-953-549-A    Type 1    SW 0030    Midline    Yes    -    -
my car already has cruise control fitted from the factory if that makes any difference
« Last Edit: June 08, 2013, 12:51:22 pm by reaper7881 »
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
You need to fit the rocker MFA Stalk
and code the module
Address 16: Steering wheel        Labels: 1K0-953-549-MY8.lbl
   Part No SW: 1K0 953 549 A    HW: 1K0 953 549 A
   Component: Lenksäulenmodul 012 0030
   Coding: 0000042
   Shop #: WSC 00152 210 91233
   VCID: 306B1614A338723
No fault code found.
Cruise, rear wiper and Trip computer
Cluster and Key coding
Location Great Yarmouth
Offline reaper7881
thats the thing
i have fitted the multi function wiper stalk but the buttons dont do anything wipers work as normal
what menus do i need to go in to to code the stalk up, are there any tutorials
thanks
« Last Edit: June 08, 2013, 01:03:00 pm by reaper7881 »
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
Have you have coded your module to 42
if you have the checkthe advanced measuring blocks for the stalk function
Offline reaper7881
ill get my mate with the computer to do it tomorrow
i have no idea whats going on
thanks
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
it won't work if it is not coded
get it coded and report back
Offline reaper7881
got it all coded up and now its working nicely
are there any hidden menus like the convenience  menu that i can activate on the speedo or do i need a new controller for that  :wink:
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
if you want Convenience then you need a MAX version
same for Lights & Vision
Offline reaper7881
whats the part number for the maxx version
Offline reaper7881
i have found a maxx ccm with part number 1K0959433BT 1K0959433AQ
i took a pic of my ccm behind the glove box
it says
HELLA KG
made in germany
01.09.04 0562610
5DK 008 583-12 HLO w42 04245 P003 0194
is the 1K0959433BT 1K0959433AQ module compatible with my car
thanks
edit: ah crap the part number is hidden behind the plastic holder thing, back in 5 need to take it apart again
new pic
VW AG 1K0 959 433 BK
KSG Max s2tuere s0301/H02
HELLA KG
made in germany
01.09.04 0562610
« Last Edit: June 29, 2013, 02:11:02 pm by reaper7881 »
