Author Topic: Actuator replacement  (Read 2803 times)
Offline adgti
« on: June 07, 2013, 10:45:49 pm »
I have pressure tested my actuator tonight & it won't hold any pressure so I am guessing that's where my power loss is.
How easy is it to change this? do I have to remove the turbo?
Also is the actuator a standard 2 bolt fitting? as I have a collins 1.2bar actuator here if it will fit#]
Thanks adam
Re: Actuator replacement
« Reply #1 on: June 07, 2013, 10:52:22 pm »
The actuator can be replaced without removing the turbo but it's a very tight and fiddly job. After install you'll need to log the car to assist correctly adjusting the pre-load pressure (done by loosening or tightening the actuator's nut).
Offline adgti
« Reply #2 on: June 07, 2013, 11:39:21 pm »
Ok so is it the standard 2 bolt fitment like most actuators?
« Reply #3 on: June 08, 2013, 10:11:50 am »
It's a 2 bolt fitment but I don't know if a universal one (fitment).
Offline adgti
« Reply #4 on: June 09, 2013, 12:57:44 am »
 :scared: Right well I think I will try & fit this tomorrow a little worried it might be overkill though the actuator is a collins -31 whatever that means :S I have a hand held vac pump & it seems to crack at 0.7bar & fully open at 1.2bar
I have a stage 2 map
One of these
I am also hoping that the thread will be the same on the actuator rod  :scared: :scared: :scared:
« Reply #5 on: June 09, 2013, 10:09:38 am »
I don't think that actuator will work/fit on your car.
Offline adgti
« Reply #6 on: June 14, 2013, 12:00:20 am »
Well I changed it the other night what a bitch of a job that was! it pulls fine now until I hit 5k I think the spring is too hard in the actuator the power just goes flat for some reason  :ashamed:
