Author Topic: Jonnyc's MK5 ED30 Build Thread..  (Read 528493 times)
Phil Mcavity
Re: Jonnyc's MK5 ED30 Build Thread..
« Reply #1020 on: May 30, 2009, 03:55:36 pm »
it had to be you Robin to start Page 69
 :wink:
« Reply #1021 on: May 30, 2009, 04:14:44 pm »
^ Looks like they are the weight saving version too! :evilgrin:
matt a
« Reply #1022 on: May 31, 2009, 03:33:45 pm »
By the potential new owner?
Offline illyun
« Reply #1023 on: May 31, 2009, 05:28:10 pm »
Depending on how the sale of the car goes ill continue the build thread here..
http://vagoc.co.uk/vb/showthread.php?t=15
Does that mean you are leaving this forum even if you don't sell the car?  :sad: :rolleye:
« Reply #1024 on: June 03, 2009, 09:08:36 pm »
Pics pics pics pics, rims rims rims rims!  :P
Offline jonnyc
  • Herrooooo!
« Reply #1025 on: June 06, 2009, 05:22:22 pm »
Here we are.. New wheels on, just a few pics to take a look at!
Pleased with the look, pretty different to the last set but at the moment the plan is to run these for the next couple of month then go from there!!
matt a
« Reply #1026 on: June 06, 2009, 05:41:35 pm »
Nice choice Jonny! I wonder how many people will assume the car is all show and no go? PMSL
So is the E30 staying?
Offline jonnyc
  • Herrooooo!
« Reply #1027 on: June 06, 2009, 06:13:13 pm »
Possibly..
Ill be running a couple of different wheels on the front end at Inters just for a couple of runs on the sprint in the afternoon..
Offline joesgti
  • Eat my sick, Eat my sick.
« Reply #1028 on: June 07, 2009, 10:50:32 am »
have you photoshopped that?
Offline jonnyc
  • Herrooooo!
« Reply #1029 on: June 07, 2009, 11:06:45 am »
Just dropped it 10mm to make up for the difference between the 235 and 215 tyre as the ride height was set for the last set.
It will sit exactly as it is in the pics though once I get the ride height adjusted..
How come??
« Reply #1030 on: June 07, 2009, 11:53:42 am »
Looks awesome Jonny  :drool: :drool: :drool: :drool: :drool:
« Reply #1031 on: June 07, 2009, 02:41:46 pm »
come on jonny we need a full on side shot of these on the car and from a few angles  :smiley:
matt a
« Reply #1032 on: June 07, 2009, 02:50:52 pm »
I guess Jonny has only put one on!? but more full car shots would indeed be great!  :happy2:
Offline Janner_Sy
  • -Receive: 113
« Reply #1033 on: June 07, 2009, 09:56:54 pm »
Quote
The next area to look at is the suspension itself, im going to be fitting a set of lightweight KW Race anti-roll bars, these are 3 way adjustable and should help control the rate of roll, just something that is nice to have, also should save me a couple of KG's which helps!
Ill be replacing the front bottom arms with OEM TT items, these are not only lighter (aluminium rather than steel) but they also offer an additional 0.5 degrees negative camber for the front end, so I should be able to run around 2.7 degrees front static camber and keep all of the caster I have too, looking forward to these!
TT arms..
Compared to stock..
They will also be fitted with the WALK and poly bushed rear bushes at the same time.. 4kg lighter than the stock items apparently too!
Quote
JonnyC have you fitted the TT lower arms, walk and rear bushings yet. if so how has it transformed. the handling of the car
« Last Edit: June 10, 2009, 04:46:33 pm by simonskerton »
Offline plush-automotive
« Reply #1034 on: June 10, 2009, 09:46:52 am »
love the new wheels jonny the car is gorgous man. :happy2:
