Author Topic: Jonnyc's MK5 ED30 Build Thread..  (Read 528755 times)
Offline KRL
  • -Receive: 29
Re: Jonnyc's MK5 ED30 Build Thread..
« Reply #1110 on: November 12, 2009, 08:01:38 pm »
Agreed.
Offline Vick N
« Reply #1111 on: November 16, 2009, 06:21:15 pm »
Awesome mate   :drool:
Offline prepree
« Reply #1112 on: November 19, 2009, 08:42:21 pm »
New turbo = Gunning for APR??
Cant wait for the updates, is it going to be the same turbs as the S3?
 :star:
Offline jonnyc
  • Herrooooo!
« Reply #1113 on: November 19, 2009, 09:18:53 pm »
 :star:
For the engine im looking at the following..
Built motor / BSH GT3076R turbo Kit / Lots of trick bits.. The aim is a solid 500hp
For the chassis and interior its going to get serious
The aim is 1000kg which is going to mean very in depth weight saving! The last time the car was on the scales it was 1190kg so there is plenty to come out..
At the moment I can see it getting down to 1050kg, thats with extensive carbon / plastic work etc and the last 50kg will come from gutting the interior and replacing with superlight weight materials..
Its in no way going to look like a shell inside though, carbon, flocking, alcantara etc etc.. All super light weight but with a high quality feel
Ha, gunning is not the word.. Running a high 11 will be VERY easy with the plans that I have, the car would do that now with slicks and race fuel on the K04!!!
Throw some race fuel and drag slicks on it (play them at their own game) And im looking to get deep into the 10's with the new spec..
Offline prepree
« Reply #1114 on: November 19, 2009, 09:29:51 pm »
[SUBSCRIBED]
 :congrats: :popcornsoda:
Offline Janner_Sy
  • -Receive: 113
« Reply #1115 on: November 19, 2009, 10:04:17 pm »
so your going to be runnig both the S3 and the Ed30 now then??? which will be quicker when finsished do you think
Offline jonnyc
  • Herrooooo!
« Reply #1116 on: November 19, 2009, 10:14:47 pm »
We'll see  :wink:
« Reply #1117 on: November 19, 2009, 10:56:42 pm »
I'm in for this one....very interested in seeing the post whereby APR defend themselves against a low 10 second car :jumping:
Offline jonnyc
  • Herrooooo!
« Reply #1118 on: November 19, 2009, 11:03:53 pm »
Exactly.. The bull sh*t will stop most probably.. They keep on ignoring the fact that the S3 is up and running and VERY quick.. Such a shame I can't do a run  :sad1:
Anyways John I have a PLAN! Need to speak to you about it.. Think it may be of interest to you  :wink:
« Reply #1119 on: November 19, 2009, 11:20:40 pm »
I'm all ears :happy2:
PM me or call in the next 15 mins or so as I've got to be up at 5 am in the morning :smiley:
« Reply #1120 on: November 20, 2009, 09:35:25 am »
Absolutely bonkers mate  :grin: :grin:
Offline NEWEY
    • Flickr
« Reply #1121 on: November 20, 2009, 09:41:37 am »
brilliant news!!! how how i would love to have two cars like this
TSR big turbo mk5 golf gti
« Reply #1122 on: November 20, 2009, 09:54:50 am »
Good luck with this Jonny i hope it shuts a few people up when its done and not on race fuel or slicks just to prove a point  :driver:
« Reply #1123 on: November 20, 2009, 10:34:29 am »
looking forward to what happens with this! :)
Offline jonnyc
  • Herrooooo!
« Reply #1124 on: November 25, 2009, 01:08:11 pm »
Hey!
This is the final list of bits, this includes all of the parts, but obviously not all of it would be done at the same time ala S3 lol..
Engine
BSH TUBULAR MANIFOLD
BSH OIL & WATER LINES - MK5 GOLF GTI
HIGH TEMPERATURE ORANGE HEAT JACKET FOR OIL & WATER LINES
GARETT GT3071R / TIAL .64 AR / BILLET WHEELS / WRC BEARINGS
GARETT GT3076R / TIAL .86 AR / BILLET WHEELS / WRC BEARINGS (TURBO UPGRADE)
TIAL MVS V-BAND 38MM EXTERNAL WASTEGATE - PURPLE
HEAD SKIM
PORTED AND POLISHED HEAD
FERREA 1MM OVER SIZED SOLID LIFTER VALVE TRAIN CONVERSION
BLOCK 83.5MM OVER BORE
JE FSI PISTONS - 83.5MM / 9.5:1 COMPRESSION / COATED CROWNS / COATED SKIRTS
INTEGRATED ENGINEERING NON TAPERED RODS - RIFLE DRILLED
ARP 2000 ROD BOLTS
CALICO COATED BIG END BEARINGS
KNIFE EDGED & BALANCED CRANK
MISC OEM ENGINE REBUILD PARTS
REVO STAGE 3 - PROGRESSIVE THROTTLE / 7200RPM / 1.65 BAR BOOST
OEM AUDI RS4 FSI INJECTORS
AUTOTECH REVISION 2 HIGH PRESSURE FUEL PUMP
OEM HPFP CAM FOLLOWER
LOW PRESSURE FUEL SYSTEM UPGRADE
NGK IRIDIUM IX SPARK PLUG - BKR7EIX
CUSTOM DV RECIRC KIT - FORGE SUPERSIZE DV (BLACK) / 25MM BLACK SILICONE / CLAMPS
CUSTOM ALUMINIUM DV RECIRCULATION PIPE
CUSTOM INLET MANIFOLD BLOCK OFF WITH DV VACCUM FEED
BSH 'VENT TO ATMOSPHERE' RACE CATCH CAN SYSTEM
BSH BREATHER HOSE HEAT INSULATION / HEAT SHRINK ENDS
REAR ROCKER COVER BLOCK OFF BUNG - 25MM BUNG / 25MM BLACK SILICONE / 2X CLAMPS
THS INTERCOOLER - MK5 GOLF GTI
CUSTOM THROTTLE BODY PIPE WITH DV TAKE OFF
CUSTOM ALUMINIUM SWAGED TURBO TO INTERCOOLER PIPE
CUSTOM 76MM TURBO INTAKE PIPE - NO RECIRC BUNG FOR ROCKER COVER
FORGE MOTORSPORT TWINTAKE - MK5 GOLF GTI
BSH 38MM EXTERNAL WASTEGATE DUMP TUBE
CUSTOM 76MM DOWNPIPE - V-BAND CLAMP FITTED AND ADJUSTED
CUSTOM 76MM CAT BACK EXHAUST
Heat Management
ZIRCOTEC PERFORMANCE WHITE CERAMIC COAT - TURBO EXHAUST HOUSING
ZIRCOTEC PERFORMANCE WHITE CERAMIC COAT - EXHAUST MANIFOLD
HEATSHIELDPRODUCTS INFERNO EXHAUST WRAP - DUMP TUBE
HEATSHIELDPRODUCTS INFERNO EXHAUST WRAP - DOWNPIPE TO TAIL PIPE
ZIRCOFLEX ABOVE MANIFOLD / GOLD HEAT WRAP - INTAKE PIPE
GOLD HEAT WRAP - DV RE RECIRCULATION PIPE
Drivetrain
REVO DSG SOFTWARE - STAGE 2
QUAIFE AUTOMATIC TORQUE BIASING DIFERENTIAL - DSG
DSG CLUTCH PACK UPGRADE
BSH RACE ENGINE MOUNT
BSH RACE GEARBOX MOUNT
BSH RACE PENDULUM MOUNT
VWR RACE SOLID LOWER MOUNT INSERT
COMPOMOTIVE M01890 - 18 X 9.0 / ET40 / 5 X 112 - SATIN BLACK (WIDE ARCHES ALL ROUND)
TOYO R888 - 265 / 35 / 18
Chassis
OHLINS 3-WAY RACE DAMPERS
CUSTOM CAMBER / CASTER ADJUSTABLE TOP MOUNTS
VW RACING SPEC KW ANTI-ROLL BAR KIT
WHITELINE ANTI LIFT KIT
POLY BUSHED SUSPENSION ALL ROUND
OEM AUDI TT BOTTOM ARMS
OEM AUDI TT FRONT HUBS - 2.0T FSI FWD
OEM VW SCIROCCO ALUMINIUM REAR SUSPENSION
VW RACING BIG BRAKE PACKAGE - RACE
Weight Saving
RECARO POLE POSITION - BLACK LEATHER / BLACK DYNAMICA
RECARO MK5 GOLF FITTING KIT & ALUMINIUM ABE SIDE MOUNTS
LIGHTWEIGHT REAR INTERIOR FLOOR & OEM BLACK CARPET
OEM REAR SEATS + BELTS REMOVED
MISC SOUND DEADENING AND HEAT PROOFING REMOVED
MISC INTERIOR WEIGHT SAVING
WIDE FRONT AND REAR ARCHES - 20MM ALL ROUND
VW RACING CARBON BONNET
VW RACING CARBON BOOT
VW RACING POLYCARBONATE REAR WINDOW KIT
SINGLE WIPER CONVERSION
LIGHT WEIGHT FRONT & REAR BUMPERS
FRONT & REAR ARCHE LINERS REMOVED
REAR SCREEN WIPER ASSEMBLY REMOVED - BLACK BUNG INSTALLED
REAR BUMPER BAR REMOVED
BRAILLE LIGHTWEIGHT 15LBS BATTERY
CHARCOAL CANISTER REMOVED - BLOCK OFF PIPE INSTALLED
AC PUMP REMOVED / RADIATOR REMOVED / AC HOSES REMOVED
LIGHT WEIGHT AC BRACKET
FULL AC REMOVED
REMOVE FOGS & HEADLIGHT WASHER SYSTEM
REAR BUMPER BAR
REAR WIPER DELETE
UNDER CARPET SOUND DEADENING REMOVED
SAT NAV / HEATING CONTROLS REMOVED
CHARCOAL CANISTER REMOVAL
REMOVE REAR SEATS
REAR SEAT BELTS
REMOVE BOOT CONTENTS
LIGHT WEIGHT HEATER SYSTEM
LIGHT WEIGHT ENGINE AND CHASSIS WIRING LOOM
ELECTRIC FRONT WINDOWS REMOVED
LIGHT WEIGHT DASH
LIGHTWEIGHT FRONT AND REAR INTERIOR DOOR TRIMS
POLYCARBONATE REAR 3 WINDOWS
LIGHT WEIGHT FRONT BUMPER BAR
Thats about where im at for now, still loads to be considered, but the idea is basically to end up with a 550hp / 1000kg Golf GTI.. With the plans for the suspension / mapping / wheel & tyre set up im confident that the car will be very drivable and EXTREMELY fast at the same time..
I know most people will see that headline figure of 550hp and say that it will be completely pointless, well, it wont  :happy2:
« Last Edit: November 26, 2009, 03:56:24 pm by jonnyc »
