Author Topic: Jonnyc's MK5 ED30 Build Thread..  (Read 519879 times)
Offline vRS Carl
  • -Given: 282
  • -Receive: 240
Re: Jonnyc's MK5 ED30 Build Thread..
« Reply #1530 on: January 24, 2010, 08:22:53 pm »
Bad workman Bad tools springs to mind  :signLOL:
Just kidding :)
I would take solace in the fact you have a Golf that has a higher terminal speed than a Nissan GT-R
Decent track etc then maybe you will achieve your goal.
If you want some lessons in how to drive in the wet though just give me a shout  :evilgrin:
Carl :happy2:
Offline jonnyc
  • Herrooooo!
« Reply #1531 on: January 24, 2010, 08:26:47 pm »
Just kidding :)
Carl :happy2:
 :happy2: :grin: I think lessons on ice driving may come in more useful!
« Reply #1532 on: January 24, 2010, 08:34:29 pm »
was it that bad down there ?
Offline jonnyc
  • Herrooooo!
« Reply #1533 on: January 24, 2010, 08:36:00 pm »
Complete joke mate.. Seriously.. I had more grip in the p*ssing it down rain on the way home.. 3rd gear full power no problem.. At the Track, 4th gear wheel spin at 100mph.. Complete waste of time
« Reply #1534 on: January 24, 2010, 08:41:31 pm »
 :sad1: give it a few months for it to heat up a little and then a trip down to york and see how it goes there save the long trip down to pod
Offline jonnyc
  • Herrooooo!
« Reply #1535 on: January 24, 2010, 08:43:57 pm »
Yup, thats the plan  :smiley: Should have built motor and the car basically done by then too.. If its still in the 12's then its either being sold or dropped off the edge of a cliff depending on how im feeling..  :wink:
« Reply #1536 on: January 24, 2010, 11:52:32 pm »
Nah, I can't see it still being in the 12's Jonny. If you managed a 119mph and were still spinning the wheels at 100mph that tells me that you'd be easily over the 124mph in the dry that you'd need in a FWD car to hit the 11's . :happy2:
The figs below were taken from www.letstorquebhp.com
Power at Flywheel (BHP) :  460
Weight without Driver (KG) :  1150
Power to Weight Ratio (BHP Per Ton) :  406.42
0 - 60 (Secs) :  4.06
0 - 100 (Secs) :  8.27
60 - 100 (Secs) :  4.21
Quarter Mile (Secs) :  12.20
Terminal Speed (MPH) :  121.43
Drag Strip Quarter Mile (Secs) :  12.00
Drag Strip Terminal Speed (MPH) :  123.67
Offline mjp
« Reply #1537 on: January 25, 2010, 09:57:19 am »
well done jc...still an achievement to run in the 12s...i am sure you gonna run a low 11s soon...
Offline jonnyc
  • Herrooooo!
« Reply #1538 on: January 25, 2010, 08:05:43 pm »
:happy2: Car goes in tomorrow for another load of bits, new coil packs / MAF / MAP as there is a slight hesitation, so want to get to the bottom of that.. A little more weight saving and (hopefully) new intake and going to try a little more boost..
Offline Janner_Sy
  • -Receive: 113
« Reply #1539 on: January 25, 2010, 08:21:15 pm »
i thought you had already done the MAF. also what is MAP, ive seen this mentioned a few times when it comes to water meth controlment signals etc
Offline snapey
« Reply #1540 on: January 25, 2010, 08:22:43 pm »
Any timeline for when you'll be having the rods and pistons dropped in?
Luke.
If you have to ask why, you'll never understand.
Offline Poppa Dom
« Reply #1541 on: January 25, 2010, 09:19:45 pm »
MAP - Manifold Absolute Pressure, map sensor readings are used to calculate air density which in turn calculates air flow and is then used to regulate fuelling.
Offline chungster
« Reply #1542 on: January 25, 2010, 09:34:00 pm »
its the sensor in the TB pipe from IC to TB.
ECU is clever u see...uses MAF to read airflow pre turbo...then MAP to check again before Intake Manifold...then uses Lambda probe to check mixture on exit!
If all is good..u get the full beans. If its bit off..u get limp mode!   :grin:
Offline Janner_Sy
  • -Receive: 113
« Reply #1543 on: January 25, 2010, 09:52:51 pm »
cheers to DOMT and chungster. might look into the same as well then
« Reply #1544 on: January 25, 2010, 09:57:17 pm »
Sort of. You can run with the MAF disconnected and still get 'the beans'.  :wink:
