Author Topic: Stage 2+ req the RS4 valve??  (Read 6061 times)
Offline KennyGTI
« on: June 10, 2013, 10:03:08 pm »
Is the RS4 valve essential for Stage 2+?
Hopefully getting this on my car in the next week or two and just wondering if it is all that essential ??
MK6 Golf R APR Stage 2+
Re: Stage 2+ req the RS4 valve??
« Reply #1 on: June 11, 2013, 08:22:06 am »
Not technically essential if your present oem one is cracking at the specified 130 bar. The RS4 one cracks at 136 bar.
Offline berg
  • -Given: 49
  • -Receive: 38
« Reply #2 on: July 15, 2013, 08:27:37 pm »
its only 30 notes so worth putting on
Offline edd666999
  • -Receive: 89
« Reply #3 on: July 15, 2013, 09:44:57 pm »
+ Fitting  :grin:
Offline dokez
« Reply #4 on: September 01, 2013, 02:16:57 pm »
+ Fitting  :grin:
Free if you know how to use a spanner :)
Offline WHOZBOSS
« Reply #5 on: September 02, 2013, 08:46:23 pm »
Where Is the best place to purchase one from?
Offline scopes
  • -Given: 131
  • -Receive: 115
  • Wolfsburg Edition
    • My GTI
« Reply #6 on: September 02, 2013, 08:50:39 pm »
VW or TPS  :smiley:
Silver is the way !
Offline scopes
  • -Given: 131
  • -Receive: 115
  • Wolfsburg Edition
    • My GTI
« Reply #7 on: September 02, 2013, 08:51:44 pm »
Does it really help make that much difference, I have heard others say the opposite...
 :confused:
Silver is the way !
« Reply #8 on: September 02, 2013, 11:11:32 pm »
It will help if your current actual pressure in the high pressure fuel rail isn't meeting requested. Generally speaking if it is meeting requested you don't really need it. You need to do the logs on VCDS to check and the best way to get a good run under heavy load is to run the car uphill in one gear from low rpm to 6500rpm. To run it as a real world pull run through three gears under high load up hill the first two only up to 5000rpms though to keep the load maxed. Safely though! You are more likely to get a drop in the high pressure fuel system against requested if you do the latter run as demand is more sustained.
Offline scopes
  • -Given: 131
  • -Receive: 115
  • Wolfsburg Edition
    • My GTI
« Reply #9 on: September 02, 2013, 11:43:10 pm »
cheers John   :drinking:
What would be the best channels to log in?
after 1st & 2nd to 5000rpm,  in 3rd gear, take it s far as the hill allows, the steeper the better I take it hill wise?
Is it something you have changed over matey?
Silver is the way !
« Reply #10 on: September 03, 2013, 07:33:02 pm »
IIRC it is measuring blocks 115-3 and 115-4. :happy2:
Yes if you can find a steep hill it is better.
I have the RS4 valve on mine and it was done as a precautionary measure as well as GIAC recommending it on their tune. :smiley:
Offline WHOZBOSS
« Reply #11 on: September 03, 2013, 10:48:07 pm »
Anyone got a part number for this please
« Reply #12 on: September 03, 2013, 10:54:07 pm »
Offline AndrewJB
  • die gelbe Baron
« Reply #13 on: September 08, 2013, 09:39:44 am »
Same as me i fitted it for the sake of it tbh
Offline Boydie
« Reply #14 on: May 14, 2014, 08:23:17 am »
When selling my Revo 2+ S3 8P I received a phone call from a guy in London (I'm from Belfast) asking me about the importance of this valve.
For the money (£30-40) and time to fit (1 hour) you may as well. It will ensure the car is running smoothly and will give you peace of mind too :)
