Author Topic: Turbo valve?  (Read 911 times)
Offline Rustybear
  • -Given: 243
Turbo valve?
« on: June 11, 2013, 05:39:39 pm »
Had the car read today due to a lack of power.
It threw up voltage to MAF and turbo valve as faults.
Before I book it in to be looked at is their anyway I can check if a pipe/clip etc has come loose going to the turbo or something?
And if so how?
Offline Scottymon
  • -Given: 83
  • -Receive: 125
  • UnNaturally Aspirated
Re: Turbo valve?
« Reply #1 on: June 11, 2013, 05:55:43 pm »
I wonder if a new DV would solve?  Are you K03 or K04?  Very easy to check on K04
Offline Rustybear
  • -Given: 243
Re: Turbo valve?
« Reply #2 on: June 11, 2013, 06:00:45 pm »
Thanks!! How do I find which one i am?
2006 06 plate if that helps?
How do I find out?
Offline Tortaruga
  • -Given: 36
  • -Receive: 105
Re: Turbo valve?
« Reply #3 on: June 11, 2013, 06:15:24 pm »
Does the power loss occur from the moment you start the car? Or only after driving a while?
'07 Red manual
Offline ripmateyy
Re: Turbo valve?
« Reply #4 on: June 11, 2013, 06:20:40 pm »
How do I find out?
If its just a standard GTI it will be KO3 if its a special edition (edition 30, Pirelli edition) it will be KO4
Offline Rustybear
  • -Given: 243
Re: Turbo valve?
« Reply #5 on: June 11, 2013, 07:45:44 pm »
From the moment you start the car. It's standard so KO3, question is how don't check the DV and/or turbo valve?
Anything else it could be?
Offline Tortaruga
  • -Given: 36
  • -Receive: 105
Re: Turbo valve?
« Reply #6 on: June 11, 2013, 08:21:50 pm »
OK it's almost certainly the maf. As a start try cleaning it with a specific maf cleaner.
If you could post the fault codes it would help.
'07 Red manual
Offline Rustybear
  • -Given: 243
Re: Turbo valve?
« Reply #7 on: June 11, 2013, 08:38:45 pm »
Ok will get hold of some. Can I use wd40 or something I can get hold of easier?
Cant remember code, but remember -
Debmister (or word simalair) voltage MAF
Supercharger/turbo valve
Offline Tortaruga
  • -Given: 36
  • -Receive: 105
Re: Turbo valve?
« Reply #8 on: June 11, 2013, 08:41:07 pm »
A new maf costs over £100 and has some sensitive parts - don't use WD40.
'07 Red manual
Offline Scottymon
  • -Given: 83
  • -Receive: 125
Re: Turbo valve?
« Reply #9 on: June 11, 2013, 08:43:08 pm »
Personally I'd grab a 2nd hand MAF just incase you screw yours up cleaning it.
Don't use WD or brake cleaner... you want electrical parts cleaner.... it's easy to foobar these things.. don't scrub it either, very little contact is advisable.
Offline Rustybear
  • -Given: 243
Re: Turbo valve?
« Reply #10 on: June 11, 2013, 09:04:56 pm »
Great will try, just to confirm the MAF is the block connection with all the wires going into on top  of engine drivers side. Do I pull out and clean just the top bit or take off completely undoing the Torx screws?
Offline Scottymon
  • -Given: 83
  • -Receive: 125
Re: Turbo valve?
« Reply #11 on: June 11, 2013, 10:42:54 pm »
I'd grab a backup so you can test to see if it is the MAF that's the issue.
To clean, you will have to remove the electrical connector then undo the torx bolts and carefully remove it from the induction pipe... spray with your electrical cleaner and allow to dry whilst still holding it and replace... I wouldn't even set it down.  If you goose it, the car may stall continuously after turning over; happened to mate of mine.
I bought a backup when I installed my CAI just incase. :happy2:
Offline Rustybear
  • -Given: 243
Re: Turbo valve?
« Reply #12 on: June 12, 2013, 03:35:47 pm »
Ok done the clean and took engine cover off to see if anything motivate detached pipe wise going to turbo, didn't make a difference and couldn't see anything :-(
Looks like having to take into garage and see what they say.
Any other thoughts on it?
