Author Topic: Complete Audio Install  (Read 6712 times)
Offline Scaff
Re: Complete Audio Install
« Reply #30 on: July 25, 2013, 09:56:13 pm »
Theres a rubber grommet behind the battery. If you take out the battery and the battery holder you will see it
Offline JoeDarKa
  • -Given: 57
  • -Receive: 73
« Reply #31 on: July 25, 2013, 10:11:50 pm »
Sweet
Offline Rob.
« Reply #32 on: July 25, 2013, 10:24:26 pm »
I started to run some speaker cable to my doors last night...am I right in thinking you basically have to take the outer door skin off to have any chance of feeding the cables through?
Offline JoeDarKa
  • -Given: 57
  • -Receive: 73
« Reply #33 on: July 25, 2013, 10:42:06 pm »
I think thats correct. Im just going to re-use oem stuff
« Reply #34 on: July 25, 2013, 10:46:35 pm »
I ran my cables through to doors with them complete
Offline Scaff
« Reply #35 on: July 26, 2013, 01:57:06 pm »
Dont be scared to take door skin off, it is really easy to do, theres a guide online showing everything. There maybe a way of running wires into the door without removing it but it will be so much easier just removing the skin.
Offline Rob.
« Reply #36 on: July 26, 2013, 02:04:00 pm »
I'd love to know how!
Scaff: the repair guide I've read talks about some special tool needed for re-connecting the door handle? Is that true?
Offline Scaff
« Reply #37 on: July 26, 2013, 02:37:36 pm »
No thats not true, ill post the links when im back later if you like. It is literally undo all the bolts around the door and it just comes off
Offline Rob.
« Reply #38 on: July 27, 2013, 09:30:54 am »
It's just the lock/handle bit I wanted to be careful of really. But yeh, would love any tips you've got!
Offline JoeDarKa
  • -Given: 57
  • -Receive: 73
« Reply #39 on: July 27, 2013, 04:16:20 pm »
Where can i get a feed from for the remote wire for the amp?
Offline Rob.
« Reply #40 on: July 27, 2013, 05:07:31 pm »
The blue wire on the back of the head unit loom is generally for amp remote turn on (assuming it's an aftermarket headunit?)
Offline Scaff
« Reply #41 on: July 27, 2013, 05:49:34 pm »
here's a guide that shows the handle bit in detail http://forums.vwvortex.com/showthread.php?2984471-DIY-Passenger-Side-Door-Skin-Removal
Trust me its so easy, I took it apart and put it all back together first time with no troubles at all. Just make sure you do one door at a time and place everything in a order so you know where it all goes back
Offline Scaff
« Reply #42 on: July 27, 2013, 05:52:57 pm »
as rob said or if you are using a standard unit, you will need an amp with auto turn on via the speaker outs or one of these little gadgets http://www.ebay.co.uk/itm/271076215492?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
Offline JoeDarKa
  • -Given: 57
  • -Receive: 73
« Reply #43 on: July 27, 2013, 06:42:57 pm »
Iv got a LOC but didnt know you can get one with auto turn on. Im using my oem headunit, i might splice into the cig lighter or something
