Author Topic: MFSW installation  (Read 994 times)
Offline n17chm
MFSW installation
« on: June 12, 2013, 10:42:38 pm »
Is there any coding required to fit MFSW buttons to a stardard cd player?
No sat nav or media (iPod in centre consol)
08 Golf GTi DSG
Offline skard
  • -Receive: 245
Re: MFSW installation
« Reply #1 on: June 12, 2013, 10:51:43 pm »
Yes, you'll need to tell your SWCM (steering wheel control module) that buttons are there via coding. You may or may not already have a high end module, you'd have to check the part number.
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #2 on: June 12, 2013, 11:17:30 pm »
if you have dsg with paddles it will be a straight swop without coding
Cluster and Key coding
Location Great Yarmouth
Offline n17chm
« Reply #3 on: June 13, 2013, 07:50:05 am »
Yes I have DSG with paddles, so I can just fit them and it requires no coding?
Offline skard
  • -Receive: 245
« Reply #4 on: June 13, 2013, 07:58:16 am »
In that case I stand corrected!
Offline Dave J
  • -Given: 45
  • -Receive: 63
« Reply #5 on: June 13, 2013, 10:36:23 pm »
Can vouch for this - Kalu fitted MFSW buttons to my '08 ED30 with DSG - no coding was required, but he did scan for faults after  :happy2:.
As my car only has the midline display, the VCDS shows an error as I still have the original wiper stalk, which has the MFD menu rocker switch on the end of it. The car sort of gets confused (I think) as it has a feed for scrolling the MFD display also via the MFSW controls.
If I ever find a set of highline 974A GTI dials, then I hope to have the stalk changed at the same time to eliminate the error.
Still, love the MFSW buttons - always found the reach to the volume knob on the mkv a bit further than it was in my mkiv, so a very worthwhile 'mod'!
Edition 30 - no. 1387
