Author Topic: front camber and lowering question?  (Read 2138 times)
Offline BMX
« on: August 11, 2009, 05:32:20 pm »
when lowering the mk5 is the front camber not afected ie made more negative? just wondering why its not adjustable?
"If Pac-Man affected us as kids, we'd all be running around in darkened rooms, munching magic pills and listening to repetitive electronic music."
Offline jonnyc
  • Herrooooo!
Re: front camber and lowering question?
« Reply #1 on: August 11, 2009, 05:43:06 pm »
Camber ends up coming off the front end as you lower this car due to the geometry.. As you lower the rear you will increase the negative camber, so its a perfect recipe for understeer.. Not that 99% of people out there check the geometry after lowering  :scared:
The only way to have adjustable camber on a Mcpherson front strut is either adjustment on the bottom arm / hub connection as in the TT or from the top mount.. Both options are readily available for our cars..
Offline Janner_Sy
  • -Receive: 113
« Reply #2 on: August 11, 2009, 07:03:55 pm »
more negative camber would surely elliminate understeer.
-1 degree is standard
mine has -1.15 degrees on my last check since lowering. when i fit my tt lower arms i should be able to get -1.15
although ive been offered H2sport top mounts in a swap which im mighty tempted in. they are 4 way adjustable to either -0, -1, -1.5, -2 degrees.
But i do agree very much so that after lowering you need geometry sorting. my cornerweighting made a huge difference
Offline jonnyc
  • Herrooooo!
« Reply #3 on: August 11, 2009, 07:26:11 pm »
If your running more at the rear than the front???
Offline Janner_Sy
  • -Receive: 113
« Reply #4 on: August 11, 2009, 08:02:46 pm »
gotcha. was abit :confused: at that. makes sense now.
