Author Topic: advice on lowering my GTI Pls  (Read 1390 times)
Offline GDubz
« on: June 13, 2013, 11:30:12 am »
Hi Guys
Considering lowering my Mk5 GTI 5Door currently on 18inch Monza's
What are the best springs or coilovers to go for in terms of cost and quality?
What is the reccomended hight reduction?
Is fitting them easy/cheap?
Many Thanks!
Offline JoeDarKa
  • -Given: 57
  • -Receive: 73
Re: advice on lowering my GTI Pls
« Reply #1 on: June 13, 2013, 07:16:59 pm »
H&R or eibach springs.
Lowers approx 30mm
Fitting can be £50 - £200ish, depending on the garage. Then you will need 4 wheel allignment after that
Offline RedED30
  • -Given: 19
« Reply #2 on: June 15, 2013, 09:58:37 am »
Hi Guys
Many Thanks!
Depends on how old/shot your dampers are - as your increasing the load/work they have to do with the lowered springs.
I personally run KW V2 coilovers and i find these more than adequate for my road use, there are others avail - Weitec, Gaz, AVO, Koni but depends if you want the ability to vary ride height? If not Koni and eibach do some very good fixed rate damper/spring combo's that aren't as pricey.
Revo Stage2 - With Linear Throttle
Revo DSG
BCS Turboback Powervalve - This is a must.
ITG Closed Intake.. wooosh
Here to enjoy and help, with a hint of sarcasm, please do not be offended
Offline GDubz
« Reply #3 on: June 15, 2013, 02:33:57 pm »
Thank you for your replies gives me something to think about  :happy2:
Offline Wragg
« Reply #4 on: July 01, 2013, 09:59:02 pm »
After talking to a friend and fellow member I'm going to go for the AP -20mm springs.. He says they are considered to match the OEM ride quality and comfort and won't cause any scuffing or tyre catching.. But my requirements will probably be different to yours.. I'm not after a big low and the style and conditions of roads in my county are not desirable at all..
