Author Topic: Superpro rear bushes & Anti Roll bars  (Read 6726 times)
Offline robern2
« on: June 14, 2013, 03:07:46 pm »
Thanks to Rob at W8 Performance for supplying the Superpro rear bushes and f/r anti-roll bars, great service once again.
The rear Superpro rear bushes were fitted a couple of weeks ago (now thoroughly bedded in) whilst the solid 24mm anti roll bars (front and rear) were fitted today courtesy of the helpful chaps at Streetwise Automotive.
My stage2+ ed30 with 41k on the clock and standard dampers already had WALK and superpro front bushes so observations are only based on the recent changes.
Settings
The bars are set rear (hard), front (soft) as I wanted more neutral/oversteer characteristics.
Initial impressions
With all the previous Superpro bits fitted I didn’t experience any increase in noise, vibration or harmonics but I was a little worried there might be a compromise with the stiffer bars. Fortunately this has not proved to be the case.
Having scratched around on a few of my favourite roads with sweeping bends I was immediately impressed by the turn in characteristics. The car responds to steering inputs in a more direct way,  its far more point and shoot oriented compared to previously where I felt the need to pre-empt a degree of body roll and tyre squirm.
The rear end feels more compliant in terms of following the line set, offering a more involving drive without risk of dramas.
Previously ARB upgrades to my mk4 turbo created the sensation of choppiness in terms of left to right weight transition particularly over bumpier roads but not so here. The car behaves in a very OEM way albeit with a positive increase to lateral stiffness.
As I don’t yet need or want a massively stiffer/shorter spring/damper combination the upgrade to Superpro bushes and roll bars offers an ideal upgrade path in its own right which for fast road purposes suits my brief perfectly.
« Last Edit: June 14, 2013, 10:50:51 pm by robern2 »
Offline Janner_Sy
  • -Receive: 113
Re: Superpro rear bushes & Anti Roll bars
« Reply #1 on: June 15, 2013, 09:11:43 pm »
Id like to see how these perform.  A little different to see they have chosen to keep the front and rear bars the same thickness/stiffness which i think will work better than a stiffer front setup. I found the eibach setup needed a more substantial rear ARB to make it work better.
H&R F-28 R-24
Eibach F-26 R-23
KW F-26 R-23
Whiteline F-24 R-24
How do these compare price wise to the other bars?
Offline robern2
« Reply #2 on: June 15, 2013, 10:58:30 pm »
They were an identical price to whiteline
Offline scopes
  • -Given: 131
  • -Receive: 115
  • Wolfsburg Edition
    • My GTI
« Reply #3 on: June 24, 2013, 02:28:00 pm »
Top service from Rob as always  :happy2:
I fitted the superpro bushes and went for whiteline ARB's front and rear, i find the car a wee bit more bouncy than before...
Not sure if it's the arb's or the superpro bushes, as both were fitted at the same time!
 :smiley:
Silver is the way !
Offline robern2
« Reply #4 on: June 24, 2013, 09:54:24 pm »
No bounce with mine. Could be the dampers I guess
« Last Edit: June 25, 2013, 06:04:36 am by robern2 »
Offline scopes
  • -Given: 131
  • -Receive: 115
  • Wolfsburg Edition
    • My GTI
« Reply #5 on: June 24, 2013, 10:09:21 pm »
 :happy2:  I'm not to sure, I am only asking, but why would you say the ARB's?
Silver is the way !
Offline Janner_Sy
  • -Receive: 113
« Reply #6 on: June 24, 2013, 10:23:19 pm »
No bounce with mine. Could be the arbs I guess
Id have said dampers if its getting bouncy
Offline scopes
  • -Given: 131
  • -Receive: 115
  • Wolfsburg Edition
    • My GTI
« Reply #7 on: June 24, 2013, 11:13:58 pm »
No cause it done it just as much on the old dampers as it does the new ones.
both kw's
old ones clubsports shocks
new ones coilovers
the settings on the arb's = front med   rear hard.
what about shorter droplinks in the front, how much of a difference would they make over my oem ones?
thanks
I should maybe more this, instead of hijacking this thread  :notworthy:
http://www.mk5golfgti.co.uk/forum/index.php/topic,49748.msg746071.html#new
« Last Edit: June 24, 2013, 11:21:02 pm by scopes »
Silver is the way !
Offline robern2
« Reply #8 on: June 25, 2013, 06:15:21 am »
Updated my post, I meant dampers honest. I had bushes fitted seperately and these only provided oem feel.
Roll bars by their nature will increase lateral stiffness but not bounce, that's a characteristic more associated with damper/spring combinations which you mention was there before
Offline scopes
  • -Given: 131
  • -Receive: 115
  • Wolfsburg Edition
    • My GTI
« Reply #9 on: June 25, 2013, 01:44:32 pm »
I was thinking it could have just been the newness of them, all the superpro bushes and maybe even the arbs bushes,,, it seems to have got less bouncy than before...
Silver is the way !
Offline robern2
« Reply #10 on: June 25, 2013, 02:14:04 pm »
fingers crossed things continue to improve for you.
