Author Topic: APR's MK6 GTi The first to be tuned in North America  (Read 16913 times)
Offline Keith@APR
  • -Receive: 36
    • Go APR
Re: APR's MK6 GTi The first to be tuned in North America
« Reply #30 on: August 14, 2009, 02:41:31 pm »
Good news, the tsi has improved fuelling system, no need for upgraded HPFP and bigger injectors for this power level.
i might need to find me a tsi soon  :driver:  :jumping:
TSI runs 150 bar standard, the APR and Autotech etc fuel pump options for the FSI only run at 130bar.. And as far as I know the stock TSI injectors can run to 450hp..
Wander if there is a difference between the stock TSI injectors and the K04 TSI injectors as fitted to the Scirocco R etc? They could well be the upgrade injector of choice for FSI engines in the future rather than the RS4's..
From what I understand, VAG will continue the use of the current ED30/S3 FSI ko4 engine in the Scirocco R and R20.  TSI injectors can't be made to work in a FSI without some serious effort.  Fitment into the head is different as well as the wiring harness and injector body style.
Offline jonnyc
  • Herrooooo!
« Reply #31 on: August 14, 2009, 02:45:35 pm »
Thanks for the info Kieth.. So is the TSI with stage 3 a much stronger package than the FSI engine with the same turbo kit?
How far do you think that the stock TSI fuel system would be able to be pushed? 400WHP??
Offline Keith@APR
  • -Receive: 36
    • Go APR
« Reply #32 on: August 14, 2009, 02:48:29 pm »
My Mk5 DSG stage 3 delivered the power in a completely different way it seemed to feel that it had more kick but i think thats because the DSG drops it a few gears and throws you back, whilst driving this MK6 i was comparing the speed gains... this car was verocious in how quick it got to 150mph, I do believe the Mk6 is even quicker.
 APR have also built APR Stage III - Supercopa Killer - GTI Racecar build watch the video ... watch the mph needle and how quick this baby gets there even more so check the 50 to 100mph
  http://www.goapr.com/media/videos/D69781F1EAEF5601/CCB08BC3EF40D884/
APR say thats a $38,000 engine apparently?? Would love to know where they come up with there pricing structure!? Thats a similiar price to some full spec GT2 engines..
And, 430whp from a little over 20psi on a GT2871R.. Hmm...  :confused:
There is a drastically different approach when building an engine for endurance racing that will last an entire season at those power levels.  Yes, its expensive, not $38k, but more than most are willing to spend.  Our GTI race cars are no where near the Supercopa Killer power levels but are over $20k to build.  Endurance Racing is just a different animal than a street car and lot's more internal parts are upgraded than you would apply to a streetcar application.
Headwork alone is $5k just for the cnc work.
This engine spools up 600 rpm's sooner than our standard FSI Stage 3, uses the same turbo and makes 430whp!  Not bhp.
Yes, with lower compression, headwork, cams, more fuel and different calibration, its very, very possible and we have done so quite nicely.  Its not always about turbo size.  Going to a bigger turbo to get more power is an easy way of doing it but moves the power band to a late performer and is acceptable for drag racing but a road course client would never, ever enjoy the late power hit of a turbo bigger than a 28 frame on the 2.0T FSI.  Efficiency is the key.  We made the right internal engine mods to increase the efficiency of how the engine the makes power with the same turbo.  Boost is up 4 psi over our production FSI Stage 3.
Offline Keith@APR
  • -Receive: 36
    • Go APR
« Reply #33 on: August 14, 2009, 02:50:20 pm »
I'd be ecstatic if mine made 430bhp at 20psi :laugh:
You would also be jesus..
To be fair its 430whp at 24 psi.  Does that make us Gods or are we still just the messiah?
Offline Keith@APR
  • -Receive: 36
    • Go APR
« Reply #34 on: August 14, 2009, 02:57:09 pm »
This kit uses a different turbo than our FSI kit.  The turbo selected for this kit provides 30 more lb ft of torque, 10 less hp but spools up 300 rpm's sooner.
Currently we are calling the TSI fueling capable of 380bhp at safe afr on pump gas but haven't completed our testing yet.
Offline jonnyc
  • Herrooooo!
« Reply #35 on: August 14, 2009, 03:01:28 pm »
 :notworthy:
« Reply #36 on: August 14, 2009, 04:09:45 pm »
 :notworthy:
 :notworthy: :notworthy:
Good to know I've chosen the best size turbo for all round performance for the upgrade from my K04  :happy2:
(GT2871R with optional .86 exhaust housing) :jumping:
Offline Keith@APR
  • -Receive: 36
    • Go APR
« Reply #37 on: August 14, 2009, 04:43:56 pm »
 :notworthy:
 :innocent:
 :grin:
At the oem map sensor limit of 24psi and the oem knock limit on pump fuel at the oem c.r., you definitely have picked the best all around performer for the FSI!
« Reply #38 on: August 14, 2009, 04:49:30 pm »
 :notworthy:
 :innocent:
 :grin:
The Compression ratio won't be stock as I've also gone for uprated pistons, rods etc :wink:
Offline Keith@APR
  • -Receive: 36
    • Go APR
« Reply #39 on: August 14, 2009, 05:09:21 pm »
 :notworthy:
 :innocent:
 :grin:
Then you should be able to run the 24 psi but with a ton of timing and make approximately 380-410whp depending on how low you go..
« Reply #40 on: August 14, 2009, 06:27:18 pm »
[/quote]
[/quote]
Ooooh, she's nice :love:
400whp would be great. Initially I've set a target of 420bhp and work from there.
Larger cooler (THS :ashamed:)
Hot climate radiator
in-tank pump
all should help :happy2:
Offline Keith@APR
  • -Receive: 36
    • Go APR
« Reply #41 on: August 14, 2009, 06:48:52 pm »
[/quote]
in-tank pump
[/quote]
What intank pump are you using?
Did you know our FSI intercooler is tested and verified effective and efficient to 600hp?
http://www.goapr.com/products/intercooler_20tfsi.html
« Reply #42 on: August 14, 2009, 06:54:43 pm »
My cooler!  :pomppomp:
« Reply #43 on: August 14, 2009, 07:02:02 pm »
Hi Keith,
Yes, I'd looked at the APR one - the THS one is almost exactly the same......same dimensions, same construction, same volume, same size pipework and also rated to 600bhp. In fact, if you scrubbed out the APR decals and the THS decals I bet you'd be hard pushed to spot the difference :wink:
Offline Keith@APR
  • -Receive: 36
    • Go APR
« Reply #44 on: August 14, 2009, 07:35:09 pm »
Hi Keith,
Linky?
Did someone knock off our design? :sad1:
