Author Topic: help!! dash warning lights  (Read 1378 times)
Offline bower
« on: June 15, 2013, 01:17:08 pm »
just started car and 3 warning lights stayed on.
The tyre pressure warning light, the yellow steering wheel and the car skidding symbol have stayed on also the esp button is lit up saying its off and no mateer how long i press it for it wont go off, ive also checked the tyre pressures and there ok. does anyone have an idea? the car drives as normal
Offline Bane
  • "I was born a handsome man and now I'm half a goat
Re: help!! dash warning lights
« Reply #1 on: June 15, 2013, 01:41:17 pm »
Apart from the steering wheel symbol and the light on the ESP button,this sound ominously similar to my recent fault with the ESP module.
Get it to a dealer or specialist and get it checked for fault codes.
Mine camr up with G41 or something and required a complete new module.
I phoned VW UK customer services and said about the number of cases I had read about on the net of the failure of ESP /ABS modules across different model ranges,Unfortunatly,this was for a different fault code from mine but VW still contributed 20% to the costs.
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
Re: Re: help!! dash warning lights
« Reply #2 on: June 15, 2013, 04:31:38 pm »
Yeah get it scanned with vcds to find out the exact problem
Sent From My Samsung S3
Offline bower
« Reply #3 on: June 16, 2013, 02:17:15 pm »
yeah will have to get it checked, it was ok when i went out this morning all the lights had gone out, then when i had parked up for some shopping, when i started the car the lights came on again so it seems abit intermittent
Offline Raffhussain
« Reply #4 on: June 18, 2013, 11:47:47 pm »
Hi,
The dash warning lights your getting are similar to the ones i got when i got a dead battery. Once i replaced the battery with a new one and i started the car and all the dash lights which you mentioned appeared. After i took it for a a drive the all disappeared.
Offline bower
« Reply #5 on: June 23, 2013, 01:01:20 pm »
thanks for that wonder if my battrys onn the way out, will get it checked cheers again
