Author Topic: Lack of power when turbo kick's in!  (Read 1561 times)
Offline sanj
  • -Given: 17
« on: June 15, 2013, 03:56:14 pm »
I've had my Edition 30 for 18 month's now with no trouble at all,had a remap put on which was fine for a couple of week's,loved the power now for some reason the car feel's as if the turbo is'nt kicking in as it should do,diverter valve is fine,no problem's when you do a scan with vagcom,it's got me confused.I've looked at the intercooler hose's from the engine bay driver's side(can't see clearly where it's connected to the intercooler,and the pipe was a orange sort of colour)and there seem's to be some sort of sludge or oil leak of some sort,could it be the intercooler pipe's? :surprised:
Offline edd666999
  • -Receive: 89
Re: Lack of power when turbo kick's in!
« Reply #1 on: June 15, 2013, 04:01:37 pm »
oil is normal in the intercooler pipes
get your car logged and see if its making requested boost/fuel levels
Offline sanj
  • -Given: 17
« Reply #2 on: June 15, 2013, 04:22:10 pm »
Hi,I don't think I worded it correctly,I meant to say that there is some leaking of oil of some sort on the plastic weather shield bit sitting under the intercooler pipe's on the driver's side.
Offline George
« Reply #3 on: June 15, 2013, 04:49:19 pm »
Maybe you have a boost leak which is pushing the oil in the intercooler pipe out? A photograph would help us.
Also, what revision diverter valve and PCV do you have?
Offline sanj
  • -Given: 17
« Reply #4 on: June 15, 2013, 05:30:09 pm »
Hi,the PCV is the latest version I think,it was fitted around a year ago and seem's fine,the diverter valve is a new revision 'G' which I fitted myself 2 month's ago,here are some picture's(sorry about the quality as I could'nt get better access)it show's the oil from above the engine bay driver's side and below the car.
[/URL]
[/URL]
Offline edd666999
  • -Receive: 89
« Reply #5 on: June 15, 2013, 05:38:35 pm »
maybe the seal on the turbo to IC has gone.
Wip the undertray off its only a few screws and you will be able to see it easily
Offline sanj
  • -Given: 17
« Reply #6 on: June 15, 2013, 06:27:39 pm »
Thank's,i'll have a look at it tomorrow sometime,it's going into my local Vag specialist on Wednesday anyway(he's a good mate of mine)but just wanted some idea of what it might have been before it goe's in. :happy2:
Offline sanj
  • -Given: 17
« Reply #7 on: June 16, 2013, 02:07:10 pm »
Look's like i'll have to jack the front up to get the weather shield plastic undertray off and it look's like a pain in the arse with only a single jack!I'll just have to hope that it is just the seal and nothing more but looking at the picture's i'm 100% sure it is.
Offline sanj
  • -Given: 17
« Reply #8 on: June 30, 2013, 12:48:50 pm »
New turbo to intercooler pipe fitted and all back to normal,is it just me but 1st and 2nd gear on the Edition30 is quite sluggish as when it's in 3rd it take's off! :smiley:
