Author Topic: Short shift for MK5 non DSG  (Read 7233 times)
Offline SteveS
Re: Short shift for MK5 non DSG
« Reply #15 on: August 21, 2009, 06:53:32 pm »
whats this side to side action thing?
SOLD!! :(
VW GTI Edition 30 No. 0551
Revo Stage2+ (LT) | Evoms Intake, K&N Filter | VWR LSD | Milltek R32 TBE | VWR Engine Mounts | VWR Big Front & S3 Rear Brakes | VWR Springs |  VWR Shortshift | SuperPro Bushes |  Recaro Seats
« Reply #16 on: August 21, 2009, 07:49:17 pm »
it reduces the distance traveled from side to side when you change gear. makes eveything feel tighter and closer on gear change. the short shift alone adjusts the front to back distance  :happy2:
« Reply #17 on: August 21, 2009, 08:28:44 pm »
I have the adjustable front back forge shifter on my 57 leon and am having issues with it.  Itgrinds 3rd and feels like it needs to go further to the right to get it into 5th...
Also when in 1st or 2nd, even thoughits in gear the stick springs back to the center!  :confused:  :'(
« Reply #18 on: August 21, 2009, 08:31:51 pm »
sounds loose dude
« Reply #19 on: August 21, 2009, 08:33:21 pm »
sounds loose dude
Bugger, any idea where?  :confused:
« Reply #20 on: August 21, 2009, 08:34:42 pm »
the bolt you tighten to adjust the % throw
« Reply #21 on: August 21, 2009, 08:36:42 pm »
Sounds like Dbilas off battery out.  Cant figure out why the shifter would spring back to the middle makes me really cautious changing 2nd to third and slow 4th to 5th.
It does it when in 5th and 6th too :'(
« Reply #22 on: August 21, 2009, 08:39:24 pm »
my mates mk4 has gone from 75% back to stirring porridge again, it happens
might not be the cause, but sounds likely to me  :happy2:
Offline wigit
  • -Given: 129
  • -Receive: 42
« Reply #23 on: August 21, 2009, 08:39:33 pm »
white gti had issues with forge on his car
« Reply #24 on: August 21, 2009, 08:41:06 pm »
Are you farmiliar with the linkage?  I have the installation Pdf if some one knows or can explain where the problem is?
Offline Janner_Sy
  • -Receive: 113
« Reply #25 on: August 21, 2009, 08:52:20 pm »
piece of p*ss mike. take you intake out, battery can stay where it is, no need to move it. you'll be able to access the adjustment nut from the top,
 if not take the linkages off. (make sure your in neutral, plus put a nail in the linkage below your gear stick for when it is tighten it up) the left hand linkage has a circular circlip, slide that off and it'll pop up, the right hand linkage is a pain in the ass, i got mine off by sliding needle nose pliers behind and levering it out.
should be easy for a fitter like yourself, shouldnt be taking hints off a sparky mate, lol :wink: :P
i can show you on PDF if need be, or if it can wait until chatham im there on from 11th and ill sort it for you.
« Last Edit: August 21, 2009, 08:54:11 pm by simonskerton »
Offline WhiteGTI
  • F-A-S-T
« Reply #26 on: August 21, 2009, 08:53:17 pm »
LOL, I still am to this day! Been mailed a potential solution today, and hopefully will be able to report back on Sunday evening whether it has actually worked!!
Yeah the bolt that adjusts the throw could be loose, or even the main bolt that holds the whole shifter assembly down to the gearbox. That sounds more likely to me....
The big bolt, you can't miss it, its the one in the centre of both shifter arms, try to see if it is all tight!
2006 E46 BMW M3 - 343hp
Offline Janner_Sy
  • -Receive: 113
« Reply #27 on: August 21, 2009, 08:55:20 pm »
cant see it being the centre bolt. that shaft has splines on it,
« Reply #28 on: August 21, 2009, 08:57:59 pm »
Thanks guys, a job for the morning  :happy2:
should be easy for a fitter like yourself at home with no tools  :sad:, shouldnt be taking hints off a sparky mate, lol :wink: :P
Hahaha, true!
Ill have a look in the mornin matey and let you know how i get on.  Had a quick go at pulling the gaiter up the other day to access the holes that lock the shifter in place but didnt want to break anything, will have another bash in day light
« Last Edit: August 21, 2009, 09:02:21 pm by Tfsi_Mike »
Offline Janner_Sy
  • -Receive: 113
« Reply #29 on: August 21, 2009, 09:04:34 pm »
pull the gaiter form the bottom side first
