October 07, 2024, 11:28:09 am
All Things Mk5
How to Guides / Troubleshooting
Heated seats stuck !
Topic: Heated seats stuck ! (Read 1172 times)
Tr0nic
Taking part
-Given: 2
-Receive: 3
June 17, 2013, 04:04:14 pm »
Well I took my GTI for a drive this sunny day, but I noticed that I was getting pretty warm despite the fact that the airco was nice and cool...
Apparantly the switch doesnt respond anymore, So it's stuck on heating 3 I estimate
Any idea what to do ?
Milltek Catback Non Resonated - K&N panel filter with Carbonspeed, NQSBBK front, Caddy rears, CF engine cover, Bilstein B8 with Eibach Prokit, DS2500 all around
danfalcon
Always Involved
-Given: 1
-Receive: 8
My Ride:
Re: Heated seats stuck !
Reply #1 on:
June 17, 2013, 05:03:13 pm »
short term fix the seats can be unplugged from the loom underneath, not sure which of the plugs it is off the top of my head though, you will need to check up as one of them is airbag
Eddie-NL
Trader - 2014
Just look at my post count
-Given: 0
-Receive: 298
My Ride:
Reply #2 on:
June 17, 2013, 05:15:35 pm »
as a temp fix you can remove the fuse
possible issue: either a sticking relay or faulty dial on the climate panel
Genuine VCDS VAG-COM HEX-USB + Genuine Vag Commander + Genuine VAG Tacho + Genuine VAG CAN PRO + RNS Manager for Video in Motion and New Pin Code for RNS510
Cluster and Key coding
Location Great Yarmouth
ali6n2
Always Involved
-Given: 1
-Receive: 12
Reply #3 on:
June 17, 2013, 09:39:03 pm »
underneath its the larger plug of the 3, should be black/purple
Tr0nic
Taking part
-Given: 2
-Receive: 3
Reply #4 on:
June 22, 2013, 01:52:19 pm »
I just removed the 30A fuse of them so now I'm not getting cooked :)
If it's the dial I need to replace the entire climatronic control panel ?
stu_no_1
Always Involved
-Given: 0
-Receive: 8
Reply #5 on:
June 25, 2013, 08:54:19 pm »
they can be picked up for about 60 quid on ebay for the whole climate control unit if thats the problem not sure how to know
All Things Mk5
