Author Topic: 2.0tfsi not issues  (Read 2034 times)
Offline n0ble
2.0tfsi not issues
« on: June 17, 2013, 08:37:35 pm »
Hi,
I have a 2.0tfsi, i was having a spirited drive then i lost power.
From then the car would jump around until around 3k rpm, still down on power after 3k but no missing.
Below 3k the car jumps around and hard to keep the car started as it just stalls when not in gear, getting lots of back fires if i try and rev. I have to keep blipping the throttle on stand still to get it to rev at all, as when i press the throttle the car tries to stall, almost like the opposite effect of what the throttle should do.
Since i let the car cool down i cant even pull off as it just stalls, unless i keep tapping the throttle to get the revs up.
I also have the below three codes, after i cleared the codes only the first code came back after a little testing, i think the 2nd and third faults codes are a result of the first fault.
I have tried changing the n276 valve to no avail.
Any help would be great :-)
3 Faults Found:
004243 - Bank 1; Fuel Measuring System 2: Malfunction
               P1093 - 008 - Implausible Signal - Intermittent
             Freeze Frame:
                    Fault Status: 00101000
                    Fault Priority: 0
                    Fault Frequency: 1
                    Mileage: 47052 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 17:51:08
             Freeze Frame:
                    RPM: 2185 /min
                    Load: 27.8 %
                    Speed: 28.0 km/h
                    Temperature: 77.0°C
                    Temperature: 24.0°C
                    Absolute Pres.: 990.0 mbar
                    Voltage: 14.224 V
004506 - Fuel Pressure Sensor (G247): Malfunction
               P119A - 001 - Upper Limit Exceeded
             Freeze Frame:
                    Fault Status: 01100001
                    Fault Priority: 0
                    Fault Frequency: 1
                    Mileage: 47053 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 18:54:58
             Freeze Frame:
                    RPM: 2921 /min
                    Load: 16.9 %
                    Speed: 54.0 km/h
                    Temperature: 77.0°C
                    Temperature: 25.0°C
                    Voltage: 14.224 V
001287 - Idle Control System RPM: Higher than Expected.
               P0507 - 001 - Upper Limit Exceeded
             Freeze Frame:
                    Fault Priority: 0
                    Fault Frequency: 1
                    Mileage: 47056 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 19:00:27
             Freeze Frame:
                    RPM: 1305 /min
                    Load: 11.8 %
                    Speed: 0.0 km/h
                    Temperature: 82.0°C
                    Temperature: 30.0°C
                    Voltage: 14.224 V
Offline dokez
Re: 2.0tfsi not issues
« Reply #1 on: June 17, 2013, 08:47:21 pm »
Log the fuel pressures, Possibly the sensor on the side of the HPFP in the engine bay. There is a revision on it. You want the (K) version i believe it is.
Offline n0ble
Re: Re: 2.0tfsi not issues
« Reply #2 on: June 18, 2013, 09:25:06 pm »
Found the issue.
My turbo intake pipe had popped off haha.
Sent from my GT-I9505 using Tapatalk 2
