October 06, 2024, 09:39:30 am
All Things Mk5
How to Guides / Troubleshooting
Removing front wheel arch linings.
Topic: Removing front wheel arch linings. (Read 5006 times)
Mk5Dom
Always Involved
-Given: 3
-Receive: 19
June 19, 2013, 03:21:25 pm »
Going to be removing the wheel arch liners tonight or tomorrow to clean all the mud, leaves and general crud from under there.
Had a quick look on R32OC and it looks an easy enough job, just removing the screws and then it just pulls out?
Does that sound right? Anyone got any pointers?
Tortaruga
Just look at my post count
-Given: 36
-Receive: 105
Re: Removing front wheel arch linings.
Reply #1 on:
June 19, 2013, 03:29:14 pm »
It's very straightforward, just a few screws and wiggle it out.
'07 Red manual
scopes
-Given: 131
-Receive: 115
Wolfsburg Edition
My Ride:
Reply #2 on:
June 19, 2013, 03:35:10 pm »
Yes just remove all the screws you see attached, also when you are in there, check above where the arch lining was you should see a foam pad, either remove it, or remove it and cut one inch of it, as this is what causes the rust issue to your archs.
thanks
Silver is the way !
Mk5Dom
Always Involved
-Given: 3
-Receive: 19
Reply #3 on:
June 19, 2013, 03:42:49 pm »
Many thanks lads, much appreciated.
Simon_2.0t
Won't Shut up.
-Given: 4
-Receive: 15
Reply #4 on:
June 19, 2013, 04:28:20 pm »
Yeap easy mate, just grab a little pot to keep all the screws in, about 15-20 in total per side.
I did my drivers side at the weekend as I was fitting my new DV. The crud that came out was a lot, esp as not the nearside (picks more muck up from curb side). Will be doing the other side asap.
All this muck was behind the arch liner, cleaned it all up nicely!
Cleaned the arch liner (both parts) as it was out:
Can clearly see the difference, shame its underneath, ha ha. Will get round to doing the others soon:
All the muck I got out:
Last Edit: June 19, 2013, 04:30:10 pm by Simon_2.0t
http://www.mk5golfgti.co.uk/forum/index.php/topic,109881.0.html
All Things Mk5
