Author Topic: ***HOW-TO INSIDE*** Replacing oil pick up pipe - Intermittent low oil pressure  (Read 32684 times)
Offline SurreyED30
That's what I said to the garage as they said what's the point yours looks fine, I just said the sumps out now and the new ones in your hand so just change it anyway. plus I got my sump blasted out so looked brand new before it got sealed back together and filled with oil lol
To be honest I would've re fitted my old one as it was mint but I'd already paid for the new one. Like you say, it's there so may aswel fit it lol
Offline SurreyED30
Offline SiofChester
Great post, anyone else not able to see the images though :(
Offline xjay1337
  • -Receive: 377
Yeah, imageshack have moved them and I don't have the pictures anymore.. not that important anyway, it's all basic  :happy2:
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=rt1v4ttps58h61uv53ga36k06t&/topic,19740.0.html
Just to add to this guide. The tool you need to get to the three f*cking bolts is a 5mm ball headed hex. At least 100mm long and 3/8" drive. You'll struggle with a regular 5mm ball headed Allen key
« Last Edit: September 30, 2015, 01:19:15 pm by rich83 »
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=rt1v4ttps58h61uv53ga36k06t&/topic,90967.msg917089.html#msg917089
I did manage with a regular ball headed allen key but i think i was just lucky. Did you get the sump off?
05 | Tornado Red | DSG
Yes. Pita. Rounded one bolt nearly. Need to have the right tools
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
The good thing about these is you can use an allan or socket. Was the pipe clogged?
« Last Edit: September 30, 2015, 07:52:23 pm by dazza »
You can only use a socket on some of them. The twat bolts need and Allen. The pick up was annoyingly clean.
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
Well its good to know its done. Have you put the sump back on? If not do a few test fits first without the sealant.
Offline galaxie500
  • 56 plate 5 door in Black Pearl Metallic
Rich very kindly guided me through the removal and replacement of my sump yesterday!
I did some of the donkey work - loosening and removing the 20 or so bolts, cleaning the sump pan and replacing most of the bolts again but I certainly wouldn't have done it without Rich's reassurance and total confidence.  Big thank you!
Kind of annoyingly (but fortunately), the sump was surprisingly crud free and the pick up pipe or suction pipe as VW likes to call it, was almost totally clean save for a few bits of muck at the very edges.
Having done it now I think trial fitting the sump without any sealant is a very good idea. We had a problem with one or two bolts that wouldn't bite cleanly which added time and a little frustration to what had been a pretty seamless operation. 3 of the sump bolts are quite awkwardly placed and only accessible using the long allen key with a ball head so any misalignment is especially frustrating. A trial fit may have prevented this.  A bungee is useful too; keeps the turbo oil return from fouling as the sump pan is removed and re-attached.
We lucked out with the weather, the 5mm ball headed long reach Allen key bit being available at Rich's local parts shop(a must have) and I especially lucked out having a patient pal like Rich to direct sump removal operations and the kind use of his driveway, ramps and tools.
I think we'll be doing Rich's sump and pick up next!
Offline xjay1337
  • -Receive: 377
Rich's total confidence from him texting me all morning  :signLOL: :signLOL:
He's alright our big chinned barstewards :)
Pickup being clean is good, means the car has been well serviced and looking after.
I wont text you again then.....
I would have rung you but lisps don't translate down a phone line very well.   :P
« Last Edit: October 01, 2015, 12:01:51 pm by rich83 »
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
Genius test your DIY skills on a members car first. :evilgrin:
