Author Topic: Statller - excellent service  (Read 2356 times)
Offline neg
  • gone old skool
« on: June 21, 2013, 06:26:03 pm »
Following a break down and having recently been to Statllers I called Steve for his advice, he suspected he knew what the problem would be so with his help I arranged for the car to be collected the following morning (flatbed), car arrived at Statllers a hour or so later and then was fixed by the end of the day !
Top service and even though they are around 60miles from me I will definitely be going back there again.
Re: Statller - excellent service
« Reply #1 on: June 21, 2013, 08:02:39 pm »
What was the problem??
Offline Scottymon
  • -Given: 83
  • -Receive: 125
  • UnNaturally Aspirated
« Reply #2 on: June 21, 2013, 08:06:16 pm »
Rusty wheel arch.
Offline Eccie
  • -Receive: 25
« Reply #3 on: June 21, 2013, 08:29:44 pm »
The poor guys had a breakdown - I don't think we should ask him what's up, could be problems with his wife or job, sexuality or other private matters !!
Didn't realise Stallers did counselling  :grin:
Offline neg
  • gone old skool
« Reply #4 on: June 21, 2013, 08:51:43 pm »
I'm close to a breakdown - but then aren't most people nowadays.
ESP:Fault on the dash, a nice selection of lights, no power (accelerator not working), misfire and some throttle type error codes.
Turned out to be the throttle body which needed replacing.
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=ckd8ccupg41v95hrgdr2aosq8v&/topic,19740.0.html
« Reply #5 on: June 21, 2013, 08:53:26 pm »
Another one.... ive lost count now of how many TB have gone wrong this year!
Offline Scottymon
  • -Given: 83
  • -Receive: 125
« Reply #6 on: June 21, 2013, 09:15:44 pm »
Why do we buy these Mk5's?  Rust - arches / sills / boot. Corrosion - wheels / badges / centres. Electrical - cruise / rear wiper. Engine - PCV / TB / DV / CF ... and cr@p brakes, hmm.
Offline edd666999
  • -Receive: 89
« Reply #7 on: June 21, 2013, 09:46:37 pm »
because when you get in turn the key and drive its fannytastic.  :driver:
Offline neg
  • gone old skool
« Reply #8 on: June 21, 2013, 10:10:46 pm »
I cant say I didnt as I have bought a Mk5 in the past but this was on a Mk6 Golf R  :wink:
Offline RENNTAG
  • Premium Performance Parts
« Reply #9 on: June 21, 2013, 10:15:35 pm »
Offline vRSAlex
  • -Receive: 253
« Reply #10 on: June 21, 2013, 11:44:49 pm »
I've got another two throttle bodies to fit next week. Dropping like flies. Utter sh*te.
Follow AKS tuning on Facebook
Offline neg
  • gone old skool
« Reply #11 on: June 22, 2013, 08:47:44 am »
I'd never heard of it but yes seems like it may be turning into one of those 'common items', not a cheap one mind. The annoying thing it being stuck with a car which wont drive - I can handle limp mode to a fashion but no power and spluttering home at 15mph is not fun.
« Reply #12 on: June 22, 2013, 10:49:57 am »
What is it that actually goes wrong with the throttle bodies? Control unit? Physically break or seize up?
« Reply #13 on: June 22, 2013, 11:12:55 am »
Sensor failure.
Offline neg
  • gone old skool
« Reply #14 on: June 22, 2013, 01:01:38 pm »
Think there are a couple in there?
My Codes:
VCDS showing fault codes in ABS and Engine modules:
ABS:
01314 - Engine Control Module
            013 - Check DTC Memory
[which means check the engine codes]
Engine:
4 Faults Found:
000546 - Angle Sensor 2 for Throttle (G188)
               P0222 - 002 - Signal Too Low - MIL ON
000291 - Throttle Position Sensor (G69)
               P0123 - 001 - Signal too High - MIL ON
008482 - Accelerator Position Sensor (G79)
               P2122 - 002 - Signal too Low - Intermittent - MIL ON
001688 - Sensor Reference Voltage C
               P0698 - 002 - Too Low - Intermittent - MIL ON
I'm back on the road now  :happy2:
