Author Topic: Fitting a TT/S3 Short Shifter - Now Fitted with pics and info  (Read 18032 times)
Offline GTI-Ross
  • Learning All The Time :)
I know alot have you have done this for your MK5, so this is just a quick post for people with a MK5 or MK6.
Ok, so Picked up my new OEM TT/S3 short shifter (part number : 8J0711046E ) from Audi.
Watched this video on how to fit it:
The only thing is that the install for the MK6 is slightly different, the second clip he removes is not a metal one. Its a white plastic one, and you have to be very careful to to break it as i have read a few heavy handed Americans have  :grin:
So here is the new one.
This is the clip you have to be careful of, lift it gently from both side, DO NOT try pry it sideways !!!
All fitted and back together:
So overall opinion: Feels really nice, you still get that great OEM feel, but with 20% less vertical movement, great OEM mod for £30.
Re: Fitting a TT/S3 Short Shifter - Now Fitted with pics and info
« Reply #1 on: June 22, 2013, 02:40:27 pm »
Excellent find Ross-wonder if that shifter shifter fits the 6 speed box in my gttdi
« Reply #2 on: June 22, 2013, 02:53:29 pm »
The part number you list and the one in the pic you fitted end differend as it ends 051e
Offline GTI-Ross
« Reply #3 on: June 22, 2013, 03:17:54 pm »
ending in 046E is the whole kit including the spring and washer, Part number you can see is just for the lever = 051E
Hope this helps.
« Reply #4 on: June 22, 2013, 04:01:55 pm »
Cheers Ross that's excellent :happy2:
Offline Matto
  • -Receive: 116
« Reply #5 on: June 22, 2013, 04:09:14 pm »
Could be a better alternative to the Forge ones. I was considering one then saw one in the flesh. Very unimpressed on the quality to say how expensive they are.
Offline GTI-Ross
« Reply #6 on: June 22, 2013, 04:51:58 pm »
You mean the forge one or the OEM S3 one?
Even the OEM doesnt look all that, but it gives a nice tight & sporty feel to it.
Offline Matto
  • -Receive: 116
« Reply #7 on: June 23, 2013, 01:59:11 pm »
The Forge one  :happy2:
Offline lee_plum
« Reply #8 on: July 07, 2013, 11:06:13 pm »
nice
Offline damoegan
« Reply #9 on: July 08, 2013, 01:13:16 am »
ED30/S3/TT all use the same shifter bracket!!
Offline daz_pd
  • My VRS
« Reply #10 on: July 08, 2013, 09:23:31 pm »
It will, used to run one in my 2.0 PD 140 Octavia, cant believe you guys have only discovered this mod now!
« Reply #11 on: July 08, 2013, 09:26:16 pm »
Cheers Gaz ..got it fitted now  :happy2:
Offline billman
« Reply #12 on: July 09, 2013, 06:02:26 pm »
I didn't know it's so cheap. I'll buy one too. Thanks for the topic!
Offline GTI-Ross
« Reply #13 on: July 09, 2013, 06:55:42 pm »
No problem mate, its a nice OEM upgrade  :driver:
« Reply #14 on: July 09, 2013, 08:02:21 pm »
mine cost me £28 through work so nice and cheap mod
