Author Topic: mk5 golf gti drinking petrol after service  (Read 2887 times)
Offline raznutz
« on: June 22, 2013, 09:08:02 pm »
Hi guy's. Since I service my car oil air and plugs. On golf mk5 gti 05reg .it seems to being drinking petrol. Any suggestions. ......
Offline swedishfireball
Re: mk5 golf gti drinking petrol after service
« Reply #1 on: June 22, 2013, 09:24:46 pm »
Could be a few things, I'd say either Incorrectly gapped plugs or if you disconnected the battery the ECU is back in 'learning mode' and will drink usually drink more than Gazza on a bender.. for a while.
Offline raznutz
« Reply #2 on: June 22, 2013, 09:33:28 pm »
Plugs are genuine and  battery hasnt been disconnected
Offline raznutz
« Reply #3 on: June 22, 2013, 09:45:19 pm »
Really need help guys
Offline Kinks
Re: Re: mk5 golf gti drinking petrol after service
« Reply #4 on: June 22, 2013, 10:18:09 pm »
Sounds like an ecu in learning mode
Sent from my GT-N7105 using Tapatalk 2
Offline raznutz
« Reply #5 on: June 22, 2013, 10:31:18 pm »
Ok
Is there anything I can do
Offline dokez
« Reply #6 on: June 22, 2013, 11:15:54 pm »
fuel leak ?
Offline raznutz
« Reply #7 on: June 22, 2013, 11:17:55 pm »
nothing seems to be leaking,ive looked when the engine was running,all i had was an oil and air filter and fuel filter replaced and wv parts..
Offline john87
  • -Receive: 53
« Reply #8 on: June 23, 2013, 10:05:23 am »
What's your average mpg after a 20-40 mile run, not flooring it?
Offline scopes
  • -Given: 131
  • -Receive: 115
  • Wolfsburg Edition
    • My GTI
« Reply #9 on: June 23, 2013, 10:36:57 am »
 :popcornsoda:
Was it filter or plugs?
 :rolleye:
Silver is the way !
Offline raznutz
« Reply #10 on: June 23, 2013, 11:01:05 am »
i get around  28 mpg before the service
well yesturday i was driving the car i looked at my display of fuel range it ad 35 left so i put my foot down for a couple of secends it went straight down to 10 miles range left.which is so wrong....
Offline madhoose
« Reply #11 on: August 20, 2013, 01:56:52 pm »
Hi,
I had a similar issue with mines after they did some work, Don't know if the GTI setup is the same though.
My problem was in the back left of the engine bay, the clips into the fuel filter where loose and when you gunned the engine the fuel was flooding out.
Might be worth a look.
Offline arris
« Reply #12 on: August 20, 2013, 02:25:46 pm »
I disconnected my battery on Friday to fit my MFSW buttons then took it on a run Saturday.
Was using cruise at about 70-80 and only got 30mpg could this be because of this learning mode?
  • -Receive: 291
« Reply #13 on: August 20, 2013, 11:25:19 pm »
Not really. Range is calculated on the fly from mpg. If I boot the car and say the mpg is 25, the range might be 250 miles. If I then drive slowly, the mpg improves and the range will improve.
You got 28mpg before the service. What did you get after?
Have you checked tyre pressures? Whenever i took the car to VW, they would decrease tyre pressures to 22psi which made the handling and mpg worse.
Offline raznutz
« Reply #14 on: August 22, 2013, 08:57:06 pm »
Its ok now.I put petrol cleaner in and its alot better.thanks
