Author Topic: AKS Brembo Big Brake Kit ~ 370mm of awesomeness...  (Read 61436 times)
Re: AKS Brembo Big Brake Kit ~ 370mm of awesomeness...
« Reply #105 on: April 09, 2014, 03:40:51 pm »
 :laugh:
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=uqurmkqmnsdbeair3fbln7ut25&/topic,19740.0.html
« Reply #106 on: April 09, 2014, 03:41:40 pm »
remember Mike diameter means nothing.....its all about the radius! so 2mm so u owe me one half smiley
Come again??
Offline danishmkvgti
  • -Given: 243
  • -Receive: 154
« Reply #107 on: April 12, 2014, 08:58:34 am »
Come again??
I assume how wide the braking surface is Rich  :smiley:
Over the top mod list ;o)
Offline DaveB@Vagbremtechnic
  • Trader - 2014
  • -Receive: 130
    • Vagbremtechnic.com
« Reply #108 on: April 12, 2014, 01:07:24 pm »
We consider effective radius in brake Calcs Rich...
Diameter is only here to sell kits
For example
TTS disc is 340mm, R32 disc is 345mm. Pad sits in exactly the same position on both is the R32 disc better even though the extra 2.5mm is just creating a lip and isn't touched by the pad???
Also you would normally use the centre point of the pad radially for calculations, some pads are available with hugely different heights from 41-54mm say.......so by using a smaller pad you are technically moving it further out...that make sense?
« Reply #109 on: April 13, 2014, 11:13:46 am »
For example
Yes that makes absolute sense.
So as i went for 340mm over 345mm,  the pad sits in the same place, same "radial position"  braking effect is the same despite loosing 2.5mm disc size radius.
« Reply #110 on: April 13, 2014, 11:29:44 am »
Does the extra diameter have much effect on heat dissipation?
Offline Janner_Sy
  • -Receive: 113
« Reply #111 on: April 13, 2014, 01:15:22 pm »
Id wager not enough to notice unless your a racing driver, racing in a racing car in a race!
« Reply #112 on: April 13, 2014, 01:46:25 pm »
I didn't ask if it would be noticeable  :P
Offline betty_swollox
  • -Receive: 29
« Reply #113 on: April 13, 2014, 08:29:36 pm »
 :congrats: that's him told
2010 Leon CUPRA
BCS Powervalve Exhaust
Revo Ceramic Intake
APR Stage 2
Offline duncatr
« Reply #114 on: August 08, 2014, 11:58:26 am »
Are these kits still available?
« Reply #115 on: August 08, 2014, 12:01:42 pm »
I don't think so....  but alex can do similar kits.
Offline duncatr
« Reply #116 on: August 08, 2014, 12:03:24 pm »
Cheers, will ask him and see what he says.
« Reply #117 on: August 08, 2014, 12:52:36 pm »
He still does the 362mm kit which is equally awesome  :smiley:
Offline duncatr
« Reply #118 on: August 08, 2014, 12:54:25 pm »
Cheers Mike, dont suppose you know the going rate?
« Reply #119 on: August 08, 2014, 03:16:33 pm »
Rich Walker 'Cupra_R' should  :happy2:
