Author Topic: Regas aircon now fan constantly on!! help  (Read 1691 times)
Offline GOLDENBOY
« on: June 24, 2013, 06:32:58 am »
Hello all
Cut long story short  had my air con regas up its not worked since had the car, had it on the vag for checks come up no fault just low on gas, so took it to car air con specialist, we first checked it for leaks which we didnt have , then we regas it up, air con still wasnt working he said electrical fault to take it to my usually vw garage, most likely compressor or the switch. Now both my fans constantly on sounds like blo#dy hoover on  :fighting:, if i put heating on both fans come on straight away if turn heater off both turn off so for now my heaters stay off, incase fans burn out, has anybody had same problem??? why have my fans just started to come on because never heard then come on before previous having the air con done  :sad1:
Candy white edition 30 / Revo stage 1 / Itg maxogen / xenons/ R32 brakes front/rear/ H&r springs / cruise/ open fogs/ Rns-510
Offline TomGTI
  • -Given: 17
  • PIRELLI EDITION
Re: Regas aircon now fan constantly on!! help
« Reply #1 on: June 24, 2013, 09:17:03 am »
I know it's no help but mine does the same, with the air con on the fan is going and sounds like a Hoover and just blows warm air.
Had a pressure test and regas and changed my cabin filter and still the same. Would love to know what's wrong.  :scared:
GTI Pirelli - Reflex Silver - 5dr - 58 - B12 Sportline kit!
Sold ~ GTI - Mk5 - Pearl Black -  Bluefin - 3dr - 08
Offline daz_pd
  • My VRS
« Reply #2 on: June 24, 2013, 09:42:25 am »
isnt there a temp sensor down there somewhere? maybe someone more knowledgeable will be here to help soon
Offline john87
  • -Receive: 53
« Reply #3 on: June 24, 2013, 09:50:01 am »
It sounds like your AC is in the 'ON' position (Or ECON light is not lit, on the older models). Try pressing this AC / ECON button when your blowers are switched on  :happy2:
Offline GOLDENBOY
« Reply #4 on: June 24, 2013, 10:16:32 am »
thanks john  :happy2:  i will give this a try see how i get on!! the problem i have is cant get to my garage for next 3 weeks due to work etc so be nice to know what the problem is incase damage being caused, both fans on constantly cant be healthy!!  :sad1:
