Author Topic: Hub nut Touque setting?  (Read 1415 times)
Offline saunders400
« on: June 24, 2013, 01:34:44 pm »
Hi does anyone know the Front Hub nut Touque setting for a 2005 mk5 golf gti??
Offline Scottymon
  • -Given: 83
  • -Receive: 125
  • UnNaturally Aspirated
Re: Hub nut Touque setting?
« Reply #1 on: June 24, 2013, 01:40:48 pm »
Monsterous iirc, something in the region of 175lb/ft
Offline Scottymon
  • -Given: 83
  • -Receive: 125
« Reply #2 on: June 24, 2013, 01:44:26 pm »
According to Haynes:
Front hub nut:     265Nm     195lbf ft :confused:
http://www.golfgtiforum.co.uk/index.php?topic=102232.0
Offline campbell511
« Reply #3 on: June 24, 2013, 02:28:56 pm »
I recall something on this about it being a strech bolt.
When i took mine off i had a new bolt and threadlocker then put the bolt as tight as i could manage.
Hope this helps
Offline Scottymon
  • -Given: 83
  • -Receive: 125
« Reply #4 on: June 24, 2013, 06:17:19 pm »
^ Yes I think it is, you should replace it... iirc there was a newer version that didn't require as much torqueing.
Offline Baz300
« Reply #5 on: June 26, 2013, 03:43:16 pm »
You need to tighten the nut with the wheel off the ground (get someone to stand on the brake pedal)
Otherwise you can damage the bearing
Offline Savo
« Reply #6 on: July 02, 2013, 11:40:38 am »
If you've got the newer 12 point axle bolt then it's 70nm/52ftlb + 90° turn when you lower the car onto its wheels.
I don't know what Haynes that info came from but if you use the search here and a quick google search you'll find that the older hexagonal axle bolt is 200nm/148ftlb + 180° turn.
Offline Tank
« Reply #7 on: July 04, 2013, 12:11:19 am »
I just had a look on autodata and that's saying 200nm + 180 degrees and make sure you use new nuts/bolts.
