Author Topic: Side Lights - bulb gone... replacement options  (Read 7368 times)
Offline Max99
  • White GTi owner
« on: June 24, 2013, 02:15:42 pm »
One of my sidelights/parking lights has gone and i'm wanting to replace it.
Options are to replace it with a standard bulb (whatever from Halfords) or to replace both with something better?
Are there any sidelight bulbs which are bit brighter that are legal/won't cause any errors etc ?
Saw these on a thread somewhere else, http://rover.ebay.com/rover/1/710-53481-19255-0/1?icep_ff3=2&pub=5575009367&toolid=10001&campid=5337067769&customid=&icep_item=350251198585&ipn=psmain&icep_vectorid=229508&kwid=902099&mtid=824&kw=lg , how hard would they be to fit?
« Last Edit: June 24, 2013, 02:19:32 pm by Max99 »
Offline trs888
  • -Given: 17
  • -Receive: 20
Offline Max99
  • White GTi owner
Re: Side Lights - bulb gone... replacement options
« Reply #2 on: June 24, 2013, 11:11:06 pm »
Cheers, do either of those require additional fittings or are they simply plug in ?
How easy is it if they are to put in?
Offline trs888
  • -Given: 17
  • -Receive: 20
« Reply #3 on: June 25, 2013, 10:31:13 pm »
just a direct replacement for the OEM bulbs bud.
one bit of advice: on the bulb holders, there are 4 bits of metal that grab the bulb. if changing bulbs i normally push them into the centre (towards eachother) but not touching to hold the new bulb in a bit tighter. use a plastic device not metal and make sure lights and ignition off when doing it so you dont short anything
oh and be careful when puting it in the hole. you dont want it to fall out  :ashamed:   :signLOL:
Offline Max99
  • White GTi owner
« Reply #4 on: June 25, 2013, 10:47:18 pm »
Thanks for your help, going to go for them.
Would you have a preference out of the 2 you posted as you've tried both?
Also last thing... may be stupid Q... but are they road legal ?
Offline trs888
  • -Given: 17
  • -Receive: 20
« Reply #5 on: June 26, 2013, 08:35:59 am »
it depends on the light you are going for. the 13 SMD has a slight blue tinge, only slight , where as the black ones are a newer chip, technically should be a tad brighter and are a more crisp white light.
black ones
13 smd ones:
oh and ive never had a problem come mot time if thats what you mean.
i had some xenon gas bulbs in that were blue but the light output was pure white, and they failed! but never on leds.
Offline Max99
  • White GTi owner
« Reply #6 on: June 26, 2013, 09:22:23 am »
Awesome, going for the black cased ones :) really appreciate your time replying   :happy2:
Offline Conrad
« Reply #7 on: June 26, 2013, 04:31:45 pm »
I've just gone for these not sure if there going to fit but look like there going to be bright! http://pages.ebay.com/link/?nav=item.view&id=271038334435.
Offline trs888
  • -Given: 17
  • -Receive: 20
« Reply #8 on: June 26, 2013, 10:27:00 pm »
no probs glad to help. this is what the forum is for!
post a pic here when youve got them in!  :party:
I had ones that were similar, they were double sided not crossed like those ones, and the can bus thing was crap. might be different for these, they are bright ill give them that! let us know how you get on with them!
you got xenons or halogen lights?
Offline Conrad
« Reply #9 on: June 27, 2013, 05:12:23 am »
Hella xenon look alikes with a 5k hid kit working a treat I'll update once fitted.
Offline Max99
  • White GTi owner
« Reply #10 on: June 30, 2013, 01:19:33 pm »
Well i've spent good 20 mins trying get the drivers side light out n failed, passenger side was so easy literally 5 seconds!
So I tried the new led in the passenger but can't seem to get it into the slot .... it's same width as bit of the original one but it's square at bottom and no curves so it doesn't seem to slot in ... any ideas?
Also does anyone know if Halfords bulb fitting service if they do it for bulbs not bought from them ?
Offline trs888
  • -Given: 17
  • -Receive: 20
« Reply #11 on: June 30, 2013, 06:56:27 pm »
they should go in, myabe the pins are not seperating. ive got them in the holder with minimal difficulty. then again ive changed them loads of times  :signLOL:
oh, and probs a no no for halords. where you based bud?
Offline Max99
  • White GTi owner
« Reply #12 on: June 30, 2013, 07:56:35 pm »
ye i'm going to have a little bash at them tomorrow, hoping my osram night breaker headlights will be here tomorrow so will do it then. Hopefully i won't be defeated
I'm Sheffield based.
Offline Max99
  • White GTi owner
« Reply #13 on: July 01, 2013, 01:24:26 pm »
headlights went in a breeze... still cant seem get drivers sidelight out or fit the led bulb into the passenger side holder #fail #grazedknuckles l
Offline paulw123
  • -Receive: 47
« Reply #14 on: July 01, 2013, 01:48:49 pm »
I had to use a pair of small nose pliers to pull the side light bulb holder out of its fitting tube. Not a nice job as you can't see what you are doing, bad/cheap design by vw.
