Author Topic: Is the S3 cooler actually worth it?  (Read 4005 times)
Offline 18Edition30
« on: June 24, 2013, 09:44:51 pm »
The s3 cooler upgrade on edition 30.....is it actually worth it?
How much bigger is the cooler than Ed30 one?
Expected benefits? More bhp? Lower intake temps?
Will
Offline edd666999
  • -Receive: 89
Re: Is the S3 cooler actually worth it?
« Reply #1 on: June 24, 2013, 09:58:08 pm »
depends on your stage of tune. but yes More bhp, Lower intake temps and more power for longer
Offline 18Edition30
« Reply #2 on: June 24, 2013, 10:07:26 pm »
Stage 1....
Offline edd666999
  • -Receive: 89
« Reply #3 on: June 24, 2013, 10:14:54 pm »
Stage 1....
IMO money would be better spent on handling/brakes mods.
But if you go further then id get one.
Offline Janner_Sy
  • -Receive: 113
« Reply #4 on: June 24, 2013, 10:19:42 pm »
IMO stage 1 it isnt needed, stage 2 you should be considering it.
Offline scopes
  • -Given: 131
  • -Receive: 115
  • Wolfsburg Edition
    • My GTI
« Reply #5 on: June 24, 2013, 10:31:08 pm »
How much more can be expected, to run it with a twintercooler?
What would the benefit's be say with a s2, s2+ ?
 :popcornsoda:
Silver is the way !
Offline edd666999
  • -Receive: 89
« Reply #6 on: June 24, 2013, 10:46:01 pm »
 :popcornsoda:
TBH i look at it that it doesn't increase power, but it allows you to go all day long keeping the same power.
As heat soak takes over your engine will lose power...think someone quoted me 1degree is 1bhp and a stage2+ k03 engine without cooler after 2 runs is 50 degrees hotter than one with a cooler, so that's 50bhp because of your temperature.
Offline scopes
  • -Given: 131
  • -Receive: 115
  • Wolfsburg Edition
    • My GTI
« Reply #7 on: June 24, 2013, 10:53:39 pm »
Ed I could not have asked for it to be explained any better  :notworthy: :notworthy:
So the temps need to be reduced to keep engine power lasting longer  :happy2:
So with the twintercooler and the s3 cooler, that would be a perfect combination?
Silver is the way !
Offline edd666999
  • -Receive: 89
« Reply #8 on: June 24, 2013, 11:28:20 pm »
that would be a good combination. I just have the s3 cooler and my temps have never been an issue.
Offline scopes
  • -Given: 131
  • -Receive: 115
  • Wolfsburg Edition
    • My GTI
« Reply #9 on: June 24, 2013, 11:36:10 pm »
I'm sure someone will be along soon, that has done both to compare  :grin:
Silver is the way !
Offline Itsagthing
« Reply #10 on: June 25, 2013, 07:23:53 am »
Just a twintercooler on my oe eddy cooler is perfect there really is no need for the s3 as well. Stg 2+
Offline berg
  • -Given: 49
  • -Receive: 38
« Reply #11 on: June 25, 2013, 08:12:04 am »
 :popcornsoda:
i run one with a twintercoooler, gained a fair bit more power but lost 10lb ft of torque due to greater area of air, still you cant feel the loss but you could certainly feel the extra power top end  :smiley:
Offline daz_pd
  • My VRS
« Reply #12 on: July 04, 2013, 08:17:39 pm »
S3 Cooler on my Stage 2 TSI, noticable difference for sure, and I find the power is more consistant, on the RR a while back on 3 pulls one after the other I was gaining power rather than losing it!
Offline DAZ1985
« Reply #13 on: July 06, 2013, 09:36:00 am »
Daz_pd have you the one with alloy ends or plastic?
Tornado ED30 #673 stage1 map, miltek cat back, Sachs clutch, panel filter, WALK, eibach pro kit, s3 brakes all round
309bhp @fly
Offline daz_pd
  • My VRS
« Reply #14 on: July 06, 2013, 10:02:24 am »
Plastic mate, everyone says the Alloy ones are better but I would say the difference would be very very slight in our climate, perhaps on a track yes, but I dont do trackdays.
