Author Topic: Starting the car properly  (Read 4674 times)
Offline john87
  • -Receive: 53
Re: Starting the car properly
« Reply #15 on: June 26, 2013, 12:35:50 pm »
The same as many others above, I press the clutch down before I start every time..
My driving instructor taught me it as good practice, takes the load of the gearbox (albeit not a lot) off of the starter motor  :happy2:
Offline dmac1969
  • -Receive: 21
« Reply #16 on: June 26, 2013, 09:09:53 pm »
The mk6 will not start unless you press the clutch down.
Same with the New 2012 on Beetle I had out for the weekend when it first came out. I always press the clutch down anyway , have done for years. As regards cooling down , by the time I get out the car , unlock and open the garage door then put the car in there , its a couple of mins gone anyway , so job done.
Offline bellios
« Reply #17 on: June 26, 2013, 10:08:18 pm »
IIRC the idling before shutting off is to stop hot oil being left in the turbo. hot oil cools down and leaves deposits on the turbo causing premature wear. your best off just driving off boost for the last bit of your journey.or at least that what ive always done. :smiley:
Offline Frenzy
  • -Receive: 29
« Reply #18 on: June 27, 2013, 02:06:38 pm »
i always depress the clutch before switching on and after a good run let her idle for a minute or two. the first thing i learnt from reading the manual when i got the car, the 2nd from reading posts on here - makes sense.
Offline phil1975
  • 2011 Gti
« Reply #19 on: June 27, 2013, 04:05:10 pm »
I have to start my mk6 with clutch down (as previously stated) and I always wait for the revs to drop down before driving off. I always let the car idle before switching off, at the end of the day you can't be harming the car by doing this so prevention is better than cure in my humble opinion.
Offline Mertyvw
« Reply #20 on: June 28, 2013, 08:07:57 pm »
I get in turn the key wait for all check lights to go and after depress clutch and  turn the key full and let the engine idle of a couple of mins(3-5mins in winter) and im off
When a complete a long journey  i wait a min or two then switch off.
Black 5 Door TDI with BBS Pescaras, R32 Spoiler, Tints All Round. RCD510,CAN 7NO I aint touching the Engine> Im frightened of power :D
My sig pic is still to big.
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=mnqntq0tsg1o80gokiiq1dsnu7&/topic,19740.0.html
« Reply #21 on: June 28, 2013, 09:14:11 pm »
I start my car...  and drive off as soon as possible.
I stop my car... turn it off and get out.
 :signLOL:
Offline Tortaruga
  • -Given: 36
  • -Receive: 105
« Reply #22 on: June 28, 2013, 09:18:48 pm »
That's not recommended. Even the owners manual says so.
'07 Red manual
Offline Itsagthing
« Reply #23 on: June 28, 2013, 09:53:42 pm »
I ALWAYS depress the clutch pedal on my edition dsg before I start it! Lol  :star:
Offline bellios
« Reply #24 on: June 29, 2013, 10:34:10 am »
the handbook my misses got with her polo must be different to the golf. Start engine (sometimes in gear). give the car absolutely no time to warm up at all before going up to 5k rpm. ride clutch etc etc
Offline RifGTi
« Reply #25 on: June 29, 2013, 01:18:49 pm »
I used to start with the clutch pedal down but stopped doing it. I probably should start doing it again.
Always let the engine warm up before putting lead on the foot lol. Personally I let it hit 90 degrees before doing anything. I always let the engine the idle at the end of the trip for at least 3mins at least 5-6 after a solid lead foot/ long journey/ Italian tune up
Offline beetie
  • -Given: 34
« Reply #26 on: June 29, 2013, 03:46:20 pm »
Always start mine with the clutch down.
 for when I stop, I take it easy for the last couple of miles. Although I'm sure the mk5 has a pump that pushes coolant around for a few minutes to help the turbo to cool, once you have switched it Off. Listen for it the next time you leave your car. It will do it every minute or so.
Offline Savo
« Reply #27 on: July 01, 2013, 02:54:20 pm »
I'm the same as most people, start with the clutch pressed down. I'll let it idle until the revs drop then drive off but wait 5-10 minutes before going into boost to give the engine time to get up to temp.
I do exactly this too just taking it easy for the last bit of the drive. I've heard that noise when turning it off and always wondered what it was.
Offline Kalpsn2000
  • -Receive: 56
« Reply #28 on: July 01, 2013, 03:05:51 pm »
I have read that it is better to drive pretty much straight after starting up, although keeping the revs low until it has warmed up, as this will transport the oil around the engine better than leaving it idling.
Any truth to that?
