Author Topic: dash warning lights  (Read 436 times)
Offline itismebigd
dash warning lights
« on: June 25, 2013, 04:54:45 pm »
Hi iv got a Q for some of the forums tech members i own a gti k03 with the k04 conversion( softwear)done with all the mods that we all fit ie milly tbe itg max forge twintercooler and so on  so too the point
i was lucky enough to been given the chance to run my car down a run way at the weekend and was able to get the car to 160mph (on speedo) and then the low break fluid warning light and audio warning came on along with abs,traction control,low tyre warning,(checked level ok)as the car has never done this before can anyone shine a light on what could of caused this too happen. im slighttly apprehensive about doing any speed in my car again till i get to the bottom of this car has never been tracked before or abused in anyway. some one please help thank you all in advance
Dougie :happy2:
Offline edd666999
  • -Receive: 89
Re: dash warning lights
« Reply #1 on: June 25, 2013, 05:10:00 pm »
http://www.mk5golfgti.co.uk/forum/index.php/topic,120.0.html
Find your nearest owner with vcds and see if he/she would be so kind as to scan your car.
Offline xjay1337
  • -Receive: 377
« Reply #2 on: June 25, 2013, 05:10:32 pm »
A runway, we believe that ;)
Scan it with VCDS probaly a faulty ABS ring which would explain all the faults but as said scan it and see and then work logically looking at wiring first.
Offline itismebigd
« Reply #3 on: June 26, 2013, 07:24:45 am »
xjay lmao it was honest :wink: :wink:thank you for your info buddy i will need to look at it through vcds
