Author Topic: RNS 310/SAT NAV  (Read 4175 times)
Offline tdibilly
RNS 310/SAT NAV
« on: June 29, 2013, 11:05:44 pm »
Ive bought a 2009/58rg golf & it has a rns 310 with sat nav, Its asking for a sat nav disc/media when i press the NAV button, does this radio need a disc inserted all the time to enable the nav to work, I presume i cant play cd's when the sat nav disc is in ?, so is the only option the SD card for playing music?, Any help would be great  including can i use ebay copy type discs? as e budget is rather tight?, Many thanks!.
Offline GTI-Pirelli
  • -Receive: 27
Re: RNS 310/SAT NAV
« Reply #1 on: June 30, 2013, 12:53:58 am »
I'm not sure about the 310 but with the 510 you get the option to install the maps or use them live from the disc.
I can't imagine that you would need the disc in as you have pointed out "how do you play CD's?"
I am surprised that you don't have maps installed or a map disc. Did you get the car from a dealer? If so, have a word with them.
2017 Audi S4
Offline tdibilly
Re: RNS 310/SAT NAV
« Reply #2 on: June 30, 2013, 10:06:00 am »
The car had stood & went flat, the radio had a code error & went to vw, the maps were aparently lost but i only found this out when about to drive off, i had already held £200 back cos he only a had copy of the service history/book from vw, I have been looking for someone with a disc so i could try b4 buying if required, do the maps go onto sd card when installed cos i believe the 310 has no hard drive?, if so how big does the sd card have to be?.
Offline tdibilly
Re: RNS 310/SAT NAV
« Reply #3 on: July 03, 2013, 02:07:03 pm »
Been looking everywhere for the rns 310 maps cheapest seem to be ebay (£30 ish), not sure if they cud be cheaper anywhere but not found any, dont sound like much but trying to keep the budget down to pay for other minor bits, plus i dont know if if there going to work as ive not seen it working?, any other suggegstions where to look or anyone local with a disc i could try to prove it works?.
Offline jbc
Re: RNS 310/SAT NAV
« Reply #4 on: July 03, 2013, 06:11:28 pm »
RNS310 maps are stored on the SD card. You'll still need to get a CD though, as the RNS reads them off the CD and encodes them to the SD card. Internet suggests its a navigation CD rather than DVD so, allowing for a bit for decompression, I would guess you only need a smallish capacity SD card.
Maps data is not free to distribute, so unless you buy a genuine original disk from a dealer then it is more than likely a pirate copy. eBay disks for £30 are almost certainly someone downloading it from a torrent site, burning a CD and selling it on for a profit.
« Last Edit: July 03, 2013, 06:14:26 pm by jbc »
2012 Mk6 GTD. Tornado Red. TPMS, RNS510 and reverse camera retrofit.
