Author Topic: Fault code DTC 00665 turbo under boost ??  (Read 24284 times)
Offline DuBBully
« on: July 01, 2013, 09:20:24 pm »
Took my car to vw for its service and they tell me I have this fault code 00665 turbo under boost coming up, they wanted to charge me £75 to investigate it but I thought I'd ask on here first to see if anyone else has had the problem and how much it cost to sort out.
Any help much appreciated.
Re: Fault code DTC 00665 turbo under boost ??
« Reply #1 on: July 01, 2013, 09:25:42 pm »
If you're prepared to investigate yourself, I would first check that your dv hasn't got a tear.
Offline Tortaruga
  • -Given: 36
  • -Receive: 105
« Reply #2 on: July 01, 2013, 09:30:56 pm »
16683/P0299/000665 - Boost Pressure Regulation: Control Range Not Reached
 Possible Symptoms
 Reduced Power Output
 Limp Mode
 Possible Causes
 Hoses/Pipes incorrect connected, disconnected or leaking
 Charger Pressure Control defective
 Turbocharger faulty
 Diverter Valve faulty
 Possible Solutions
 Check Hoses/Pipes to/between Components
 Check / Clean / Replace Charge Pressure Control
 Check Turbocharger
 Check Diverter Valve
 Special Notes
 When found in 2.0l TFSI:  Check Boost Pressure Control Valve (N249), for cracked rubber diaphragm. A new/optimized Valve is available under Part # 06H-145-710-D (or newer).  RoW vehicles see: TPI 2016331 for details.
 NAR vehicles see: TSB 01-07-70 or 2013392 for details.
 When stored in conjunction with misfire codes and/or fuel trim faults see the notes associated with the following faults regarding PCV failure: Crankcase Breather Valve
 If the Turbocharger is faulty due to mechanical / internal problems or the exhaust system is restricted (typically the Catalyst) this fault may be the end result.
 When found in VW Golf/Jetta (1K): 2.0l CR-TDI (CBEA/CJAA):  Verify the mechanical part of the Exhaust Valve Control Module (J883) is not siezed or binding.
'07 Red manual
