Author Topic: Yet another throttle body bites the dust!  (Read 17115 times)
Offline cupra_k1
« on: July 03, 2013, 07:58:35 pm »
Seems my throttle body has died  :sad1:
EMS light lit up on the dash and no power at all, so  I plugged the car into VCDS and found the following fault code:
000546 - Angle Sensor 2 for Throttle (G188)
               P0222 - 002 - Signal Too Low
             Freeze Frame:
                    Fault Status: 01100010
                    Fault Priority: 0
                    Fault Frequency: 1
                    Mileage: 59777 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 16:46:11
Can anyone advise me the best place to source a new one and how much I'm looking to pay?
« Last Edit: July 03, 2013, 08:20:20 pm by cupra_k1 »
Offline Scottymon
  • -Given: 83
  • -Receive: 125
  • UnNaturally Aspirated
Re: Yet another throttle ody bites the dust!
« Reply #1 on: July 03, 2013, 08:04:48 pm »
ffs, these are dropping like flies; what's the mileage / tune - also what's the symptoms before death?
« Reply #2 on: July 03, 2013, 08:19:37 pm »
Mine Died on Saturday  :sad1: :sad1: :sad1: :sad1:
Alex at AKS is fitting mine this week
Offline cupra_k1
« Reply #3 on: July 03, 2013, 08:20:06 pm »
37k wtf. :rolleye: Do I own a ridicolous Mk5, on 118k orig clutch/dmf/tb tuned since 50k!!
No symptoms at all mate. I just squirted it out of a junction and the power instantly cut back, the EMS appeared on the dash and would not build boost. I cleared the fault and all was well till I planted the throttle again.
Yeah the cars only covered 37k and is running Stage 2+ and WMI. Maybe the WMI is a contributing factor?
Offline cupra_k1
« Reply #4 on: July 03, 2013, 08:21:21 pm »
Do you know what Alex charges to supply only mate?
Re: Yet another throttle body bites the dust!
« Reply #5 on: July 03, 2013, 08:21:39 pm »
It's happened on a wide variety of Tfsi Stock, tuned, new & old.  :sad1:
Mines at 69k miles
« Reply #6 on: July 03, 2013, 08:26:35 pm »
Can tell you when I get mine fixed mate, or drop him a PM  :happy2:
Offline martziniuk
« Reply #7 on: July 03, 2013, 08:34:49 pm »
Are you using a spacer?
121k here with never any issues.
Offline vRSAlex
  • -Receive: 253
« Reply #8 on: July 03, 2013, 08:45:26 pm »
Prob wont be the wmi that's caused it. Just that the old vdo throttle bodies are sh*t.
Follow AKS tuning on Facebook
Offline AndrewJB
  • die gelbe Baron
« Reply #9 on: July 03, 2013, 08:51:05 pm »
Alex will mine have a VDO one? or they different on the CDLA?
Offline cupra_k1
« Reply #10 on: July 03, 2013, 08:54:54 pm »
Yes mate I am using a spacer, but I'm running a dual nozzle setup so actually injecting before the TB aswell. I have had WMI switched off for the 3-4 weeks though, so I don't think its down to meth ingress.
Offline pd9264
« Reply #11 on: July 03, 2013, 09:58:40 pm »
I got one if interested. 45quid posted. It's a used one but works fine got it spare when I bought a replacement engine. Pm if interested
Offline scopes
  • -Given: 131
  • -Receive: 115
  • Wolfsburg Edition
    • My GTI
« Reply #12 on: July 03, 2013, 11:09:20 pm »
now on to revision Q  :signLOL:  my flapper motor was the next thing to go  :sad1:
Silver is the way !
Offline Scottymon
  • -Given: 83
  • -Receive: 125
« Reply #13 on: July 03, 2013, 11:14:38 pm »
Prob wont be the wmi that's caused it. Just that the old oem throttle bodies are sh*t.
What do you replace them with?
Offline vRSAlex
  • -Receive: 253
« Reply #14 on: July 03, 2013, 11:18:24 pm »
Every used one I've fitted, even if it was known to work, ended up not working and having the same fault.
Only fit new ones now.
