Author Topic: Yet another throttle body bites the dust!  (Read 17100 times)
Offline vRSAlex
  • -Receive: 253
Re: Yet another throttle body bites the dust!
« Reply #30 on: July 05, 2013, 08:10:15 pm »
New throttle body arrived today (thanks Alex), so I got to work fitting it tonight.
Once fitted, I cleared the fault code and did a throttle body alignment then took it for a quick spin. Full throttle/power is back now and no more EMS light, so I'm a happy bunny!  :smiley:
Sweeeeeeeeet  :happy2:
Follow AKS tuning on Facebook
Offline scopes
  • -Given: 131
  • -Receive: 115
  • Wolfsburg Edition
    • My GTI
« Reply #31 on: July 05, 2013, 09:37:54 pm »
now on to revision Q  :signLOL:  my flapper motor was the next thing to go  :sad1:
Throttle body failure can cause the flapper motor to die too.  Sometimes brings up the flapper fault, but leaving the car for a few days tends to clear the fault for good.
 :signLOL:
It was an old part anyway, rev c ... the new part rev E must be faster with more bhp  :wink:
              Address 01: Engine       Labels: 06F-907-115-AXX.lbl
Control Module Part Number: 1K0 907 115 J    HW: 1K0 907 115 F
  Component and/or Version: 2.0l R4/4V TFSI     0030
           Software Coding: 0403000318070060
            Work Shop Code: WSC 00191 264 15243
                      VCID: 2D555FF0B4043C70BBD
3 Faults Found:
004248 - Intake Manifold Tuning Valve Position Sensor (G336)
               P1098 - 001 - Open or Short to Plus - Intermittent
             Freeze Frame:
                    Fault Status: 00100001
                    Fault Priority: 0
                    Fault Frequency: 1
                    Mileage: 139300 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 22:21:35
             Freeze Frame:
                    RPM: 5295 /min
                    Load: 12.9 %
                    Speed: 106.0 km/h
                    Temperature: 55.0°C
                    Temperature: 19.0°C
                    Absolute Pres.: 980.0 mbar
                    Voltage: 14.097 V
001089 - EVAP Emission Control Sys
               P0441 - 002 - Incorrect Flow - Intermittent
             Freeze Frame:
                    Fault Status: 00100010
                    Fault Priority: 0
                    Fault Frequency: 1
                    Mileage: 139304 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 22:27:55
             Freeze Frame:
                    RPM: 829 /min
                    Load: 1.2 %
                    Speed: 0.0 km/h
                    Temperature: 80.0°C
                    Temperature: 24.0°C
                    Voltage: 14.097 V
012599 - Intake Manifold Runner Control
               P3137 - 001 - Basic Setting not Completed - Intermittent
             Freeze Frame:
                    Fault Priority: 0
                    Fault Frequency: 1
                    Mileage: 139305 km
                    Time Indication: 0
             Freeze Frame:
                    RPM: 0 /min
                    Load: 0.0 %
                    Speed: 0.0 km/h
                    Temperature: 67.0°C
                    Temperature: 46.0°C
                    Voltage: 12.700 V
Readiness: 0000 0000
Cleared them and hope they don't come back  :fighting:
Any Idea, what's up here?
thanks
Silver is the way !
Offline GarethB
« Reply #32 on: July 05, 2013, 10:44:49 pm »
Replacement arrived this afternoon, fitted and just arrived at hotel ready for inters
Massive thank you to Alex for telephone support today - much appreciated mate. I'll buy you a drink tomorrow to say thanks  :happy2:
Offline Gti400
« Reply #33 on: July 05, 2013, 11:21:12 pm »
Can anyone shed any light on why so many of these are failing yet? Seems strange that so many of these are failing so dramaticaly a lately :scared:
Offline neg
  • gone old skool
« Reply #34 on: July 06, 2013, 12:07:56 am »
Mine went 2 weeks ago, only 19k miles on a Golf R.
New retail on the part is around £350 alone.
Offline cupra_buzz
« Reply #35 on: July 09, 2013, 11:15:22 am »
So here we go guys. It's not looking good at all. I have had my manifold replaced with new motor and that isn't the fault. The guy has cleared all faults apart from one which says about a wire. It's in German but It's a low signal to the manifold motor. He is still looking at it.
Offline vRSAlex
  • -Receive: 253
« Reply #36 on: July 09, 2013, 03:30:18 pm »
Did they change the wiring under the inlet manifold that goes to the injectors Ben?
Offline cupra_buzz
« Reply #37 on: July 09, 2013, 04:05:56 pm »
I don't believe so. Why? Could this be the root cause?
Offline danishmkvgti
  • -Given: 243
  • -Receive: 154
« Reply #38 on: July 09, 2013, 04:07:21 pm »
VW has at some point recommended to change the wiring to the TB
Over the top mod list ;o)
Offline vRSAlex
  • -Receive: 253
« Reply #39 on: July 09, 2013, 04:07:35 pm »
Manifold comes with the wiring.  Get that changed over.
Offline cupra_buzz
« Reply #40 on: July 09, 2013, 04:09:43 pm »
So the wiring to the manifold needs to be new? As I have to try describe it in German
Offline cupra_buzz
« Reply #41 on: July 09, 2013, 04:27:57 pm »
So I just called the garage and he said the wiring is brand new and he is thinking of taking it to a specialist to have a look at the electrical parts.
Offline vRSAlex
  • -Receive: 253
« Reply #42 on: July 09, 2013, 04:44:16 pm »
So he put the new wiring on it?
Offline cupra_buzz
« Reply #43 on: July 09, 2013, 04:53:36 pm »
I believe so I ask him a couple of times so I hope so.
Offline cupra_buzz
« Reply #44 on: July 11, 2013, 09:14:36 am »
Good morning!  :party:
So I just spoke to Robert at H+G Tuning in Paderborn. And its been for an all night session at the electronic specialist.
Everything is now perfect apart from one minor fault and its the ECU :/ but my car is going in there properly on Monday. He said he should be able to repair the ECU so I am hoping next week I get the all okay and collect my car.
Hope this helps with anyone else's problem.  :happy2:
