Author Topic: Yet another throttle body bites the dust!  (Read 17118 times)
Offline vRSAlex
  • -Receive: 253
Re: Yet another throttle body bites the dust!
« Reply #60 on: October 13, 2013, 10:35:33 am »
What plugs and coils packs are you running?
Follow AKS tuning on Facebook
Offline neg
  • gone old skool
« Reply #61 on: October 13, 2013, 08:13:27 pm »
You think it could be plugs/coilpack related - they are stock coils and some slightly better plugs, cant remember which at the mo.
Always with these codes :
008196 - Intake Manifold Flap; Bank 1
               P2004 - 001 - Stuck Open - Intermittent
08212 - Intake Manifold Flap Position Sensor (Bank 1)
               P2014 - 001 - Electrical Malfunction - Intermittent
sometimes this too...
00262 - Manifold / Barometric Pressure Sensor (G71) / (F96)
               P0106 - 004 - Implausible Signal - Intermittent - MIL O
« Reply #62 on: October 13, 2013, 08:36:28 pm »
Neil try doing the output test for the manifold motor.
open vcds>engine>output test 03
then select Intake manifold flap from the drop down list
While the test is running the actuator arm should move to fully open and close the flaps
Additionally if you took your car to Stattlers then could it be Nology silver plugs you have in?
Offline neg
  • gone old skool
« Reply #63 on: October 14, 2013, 07:15:45 pm »
Nology that's the fella's
Don't have the car at the moment but I did try a RF adaption which just errors when at fault.
The dealer had found that when run the flap is being opening incorrectly due to the ECU error being logged but the flap is working correctly.
Sent from my iPhone using Tapatalk - now Free
Offline vRSAlex
  • -Receive: 253
« Reply #64 on: October 14, 2013, 07:25:52 pm »
Swap back to some stock plugs and see if the fault still appears.
