Author Topic: Strange grinding sound  (Read 4367 times)
« on: August 16, 2009, 05:24:08 pm »
Hi guys. I've got a strange grinding or rubbing sound on my car. It's coming from the drivers front wheel arch when I'm turning left. It's getting worse and worse. It used to only happen on full lock but but I've noticed it's happening more now. I've got gen 19 inch bbw alloys at 8 inch wide. The offset is 50 and I'm using eibach sportline springs. I've had a good look around the arch and can't see any obvious rubbing evidence, or any clearance issues. I've had a look on the wishbone, strut, arb and track rod and can't see anything. I've not had chance to take the wheel off yet but I wondered if any one else had cone across this before?
By the way, I had taken the screws out of the arch tops. It's not that. It doesn't have that kind of rubbing sound, it's more of a worrying metallic sound, grinding almost :(
Great stuff
your wisdow and offtopic Charm will be greatly appreciated
jacko78
Re: Strange grinding sound
« Reply #1 on: August 16, 2009, 05:31:12 pm »
jpc cpuld it be your bearings as this is a weak point on mk5 ive had 3 changed in a year and half of ownership
Phil Mcavity
« Reply #2 on: August 16, 2009, 05:36:31 pm »
Steering Rack??
« Reply #3 on: August 16, 2009, 05:41:43 pm »
Check your wheel bolts.!
I had a similar issue on the passenger side and two bolts were loose.  :ashamed:
Tyre fitter hadn't tightened them up right from 3 days before :sick:
« Reply #4 on: August 16, 2009, 05:46:52 pm »
It is a shot wheel bearing kind of sound. But it's strange it only does it on lock
« Reply #5 on: August 16, 2009, 05:49:12 pm »
I'll check that john thanks
Offline billyboy
  • Billy lar
« Reply #6 on: August 16, 2009, 05:49:20 pm »
check for a trapped stone behind disc and dust sheild, maybes
bill
Offline Janner_Sy
  • -Receive: 113
« Reply #7 on: August 16, 2009, 05:55:38 pm »
wheel bearings make a deep groaning type of sound. jack your car up and have a shake of your wheeltop to bottom there should be no play
« Reply #8 on: August 17, 2009, 12:46:34 pm »
Wheel bearing sounds and feels ok. I think it might be the cv joint? I'm not as clues up as some on here so might be wrong. I've had the wheel off, the bolts were fine. No stones in the splash guards. There's no wear or rubbing marks anywhere. Nothing. Looks like a Vw jobbie. Now, if it was the cv joint, would Vw warranty have an issue with there being 19" bbs' on there?
Offline gazbutS3
« Reply #9 on: August 17, 2009, 12:48:01 pm »
take them off, I'll "mind" them for you :happy2:
« Reply #10 on: August 17, 2009, 12:49:05 pm »
Haha I'd take you up on that if you've got some gen vag 18 inch wheels
Offline NotNormal
« Reply #11 on: August 17, 2009, 12:52:32 pm »
As bizare as it sounds, check for a small stone trapped between the back face of the disc and the inner face of the disc sh*t sheild - i had exactally the same problem a while ago.
Don't judge me by your ability !
__________________________________
Current daily crapper - Audi A6 Avant 3.0tdi SLine Quattro
Previous favourite rides :
BMW E92 335d M/Sport (351/520)
BMW  E92 335d SE (339/500)
Golf MK5 GT170 Diesel Sport (220/330)
Audi S4 (B6) - Noggy blue (366bhp)
Evo VI (6 ;) ) RSII - Scotia White (420bhp)
Astravan Sportive 1.9 CDTi - 190bhp
Astra GTE (MK2) Turbo (
Offline gazbutS3
« Reply #12 on: August 17, 2009, 12:58:44 pm »
got sum S3 1's, straight swap do ya :laugh: :laugh: :laugh: :laugh: :laugh:
or you can have the 16's off gerts Leon :smiley:
« Last Edit: August 17, 2009, 01:07:35 pm by gazbutS3 »
« Reply #13 on: August 17, 2009, 01:06:49 pm »
Already checked for stones mate :( booked the car in to the stealer tomorrow morning I'll see what they say about waranty then. They noRmally struggle pulling a fast one on me anyway!
Offline neg
  • gone old skool
« Reply #14 on: August 17, 2009, 04:25:45 pm »
They might have an issue on the wheels or lowering probably more - angle of things etc etc - depends on your dealer.
I've had an issue before when the dealer wouldnt do anything due to an aftermarket part, took it back standard and they work on it no problem - just like to cause you grief.
