Author Topic: Control modules using Micro-can?  (Read 2268 times)
Offline brady88
« on: July 04, 2013, 08:09:44 pm »
Are these the only control modules available on VCDS when using a micro-can?
I'm trying to gain access to the control module 35-Centr. Locks but it isn't in the installed list and hence doesn't let me in :(
Offline doylebros
Re: Control modules using Micro-can?
« Reply #1 on: July 04, 2013, 08:57:00 pm »
Looks that way - limited operation!
Thought this link might help you
http://www.vaglinks.com/Docs/VW/MKV/DPham00.info_VW_MKV_VAGCOM_Tweaks_And_Info.pdf
But I may be jumping in with both feet!
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #2 on: July 04, 2013, 09:12:46 pm »
you can only access control modules that are installed
35 central locks is on older vehicles which use the HEX and not the CAN
what are you trying to do?
Cluster and Key coding
Location Great Yarmouth
Offline brady88
« Reply #3 on: July 04, 2013, 09:42:24 pm »
Mate that document is tremendous!!
Thanks a bunch! :)
Managed to get everything I needed ;)
Offline brady88
« Reply #4 on: July 04, 2013, 09:44:22 pm »
Was getting rid of the single door unlocking function... my girlfriend is fed up getting caught in the rain while I'm inside haha! :p
Offline doylebros
« Reply #5 on: July 04, 2013, 10:02:55 pm »
This may also help you  with your VCDS Tool:-
http://forums.vwvortex.com/showthread.php?5010762-DIY-VCDS-(Vag-Com)-for-Beginners&p=67368983&viewfull=1#post67368983
Again hopefully not jumping in with both feet!
