Author Topic: Grinding/ rumbling noise  (Read 3506 times)
northyracing
« on: July 04, 2013, 08:48:14 pm »
At lows speeds like walking pace I get a grinding/ rumbling noise comeing  from front of my car almost sounds and feels like rusty discs but soon as I hit over walking pace it's back to normal no noise what so ever
Offline brookesb32
  • -Given: 59
  • -Receive: 75
Re: Grinding/ rumbling noise
« Reply #1 on: July 04, 2013, 11:10:56 pm »
Something stuck? Sounds like mine did (thread on here about caliper). Could be small so only here when car moving slowly?
northyracing
« Reply #2 on: July 05, 2013, 08:05:03 am »
Yeah thats sounds about right actually. Never thought of caliper i will have to investigate that
Offline CarlW
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,92229.msg927100.html#msg927100
« Reply #3 on: July 08, 2013, 10:17:44 pm »
May sound daft but does this happen at around 1800 revs or so..? Even if stood still? My 1.6 fsi has a noise that sounds similar to yours and it is my air intake that vibrates but when someone else presses the throttle and I put a bit of pressure on the top of it with my hand or something the noise stops.. Could be the same thing so give that a try and have a look at that..
northyracing
« Reply #4 on: July 09, 2013, 09:51:14 am »
Nah its only when moving slowly i tried the brakes but its not that it almost sounds like driveshafts rubbing on something like a dry bearing noise if that makes sense
Offline doylebros
« Reply #5 on: July 09, 2013, 05:24:31 pm »
Manual or auto?
If manual not uncommon for clutch rattle noise at tick over !
northyracing
« Reply #6 on: July 09, 2013, 06:08:01 pm »
Manual. It's not clutch it's when the car is moving even out of gear at very low speeds
Offline doylebros
« Reply #7 on: July 09, 2013, 07:33:30 pm »
Try driving at the same slow speed going full lock to lock (in large open space) to see if the noise stops in either direction.
northyracing
« Reply #8 on: July 10, 2013, 08:14:01 pm »
Tried the steering and its not that
Offline doylebros
« Reply #9 on: July 10, 2013, 08:38:12 pm »
Double check the rear brakes cause it sounds more like a lazy handbrake cable!
northyracing
« Reply #10 on: July 10, 2013, 10:01:48 pm »
It's from the front end sound like its down by the driveshafts/ gearbox in the center
Offline doylebros
« Reply #11 on: July 10, 2013, 10:33:33 pm »
Cv joints normal just click under full lock when failing.
Wheel bearing - check for play but normal signs are at speed and when not at speed they tend to be well worn so have plenty free play!
northyracing
« Reply #12 on: July 10, 2013, 10:43:42 pm »
At speed no noise whatsoever only literally walking pace it's hard to explain the noise
northyracing
« Reply #13 on: July 20, 2013, 07:06:03 pm »
Listening abit more today its sounds like drive shafts grinding anyone had similar
Saintsteve
« Reply #14 on: July 20, 2013, 07:10:13 pm »
What tyres do you have on the front?
