Author Topic: lets discuss 2.0TFSI crankcase ventilation : PCV options etc  (Read 19750 times)
Offline BMX
Re: lets discuss 2.0TFSI crankcase ventilation : PCV options etc
« Reply #30 on: August 17, 2009, 06:29:52 pm »
^^^^^^^^ the kit is only £100 cant be worth trying to make your own ???
    SO , I VE BEEN LOOKING AT THIS FOR A WHILE NOW , WHICH IS THE BEST SET UP TO GO FOR ??????
 my cars only done 7 k miles so should not be too messed up  :happy2:
where is it £100?
"If Pac-Man affected us as kids, we'd all be running around in darkened rooms, munching magic pills and listening to repetitive electronic music."
« Reply #31 on: August 17, 2009, 06:30:45 pm »
where is it £100?
I think that is for the revamp without the catch can...
Offline BMX
« Reply #32 on: August 17, 2009, 06:35:46 pm »
where is it £100?
yep £180 plus delivery or try your luck on ebay auction
Offline DanGB
  • Different
« Reply #33 on: August 17, 2009, 07:00:22 pm »
I got mine for £112 off ebay. from the UK distributor.
Seat Leon Mk2 TFSI sport 4WD sleeper - Breaking
Buld thread: http://www.mk5golfgti.co.uk/forum/index.php/topic,45377.0.html
« Reply #34 on: August 17, 2009, 07:35:52 pm »
That's quite a bargin...    :happy2:
Offline cmdrfire
    • Commander Fire - my blog
« Reply #35 on: August 17, 2009, 07:41:33 pm »
I imported my BSH stage one from BSH direct for around £100.
Worth it in my opinion... I've been thinking about the catch can for a long time but meh.
Offline candy turbo
« Reply #36 on: August 17, 2009, 08:32:33 pm »
yep , latest version with catch can from uk importer on ebay is £108  :happy2:
« Reply #37 on: August 17, 2009, 09:06:02 pm »
Link please  :happy2: i have bid on two of these over the last week after PG got his for £100 and they have both gone for over £150  :sad1:
Offline SteveP
  • -Given: 117
  • -Receive: 340
    • My Project
« Reply #38 on: August 17, 2009, 09:07:08 pm »
Edit was just above to post the same as TC,  as he says the starting price is £100 for the Stage 2 kit, the latest one to finish in 2 hours is already at £146.
I was lucky to get mine when they first started selling them so got it for £100 as no one else bid on it  :smiley:
Offline Deako
  • -Given: 38
  • -Receive: 44
  • Eat, Sleep....VAG
« Reply #39 on: August 17, 2009, 09:08:20 pm »
I bought the stage 1 fix on the buy it now earlier for £76 inc P&P. Watched all the stage 2 fixes lately, but everyone has cottoned on, and they dont go cheap any more.
#1493
Offline john_o
  • -Given: 136
  • -Receive: 108
    • My Car Blog
« Reply #40 on: August 20, 2009, 02:11:10 pm »
ok , quick summary so far
in the meantime a BSH PCV fix possible ebay / group buy thread... has popped up...
MOT compliant options
EuroJet PCV valve
uprated check valve & hose in the OEM location
£40
Forge oil seperator manifold and catch tank
(not yet available but coming soon)
BSH Stage 1
no can , oil fumes still circulate
BSH Stage 2
(note there is an upgrade kit available from stage1 , which I presume adds a modified 'plate' and a catch can)
(there also appears to be a high capacity catch can with dipstick measure (from 7 to 32 floz) kit available , those above use the small catch can)
Non MOT compliant
BSH Race version
or DIY vent to air!
General Info
General BSH PCV page
http://www.bshspeedshop.com/store/home.php?cat=1011
seafoaming info : http://www.golfmkv.com/forums/showthread.php?t=81247
add RR great pic link
« Last Edit: August 21, 2009, 07:39:38 am by john_o »
Red ED35 5dr DSG
BLOG | BUILD
« Reply #41 on: August 20, 2009, 02:21:15 pm »
Just be careful if you want to purchase the larger size can as I'm pretty sure it won't fit on the driver's side with the charcoal cannister in situ. It should fit on the passenger side though.
Offline DanGB
  • Different
« Reply #42 on: August 20, 2009, 02:35:27 pm »
for the guys who have these installed, whould the tap at the bottom be screwed in at all times or open up, as ive been running mine for over 500miles and nothing has collected in there yet..
Offline john_o
  • -Given: 136
  • -Receive: 108
    • My Car Blog
« Reply #43 on: August 20, 2009, 02:35:52 pm »
cheers bacillus  :happy2:
would you consider the 'small' catch can to be sufficient?
and if it fills up fully is that an issue?
Red ED35 5dr DSG
BLOG | BUILD
« Reply #44 on: August 20, 2009, 02:55:46 pm »
I think the smaller can is more than adequate for most folk provided you drain it every 1500 miles or so initially.
What's captured in the can really varies from car to car, what type of driving you do and time of year (you collect more during the colder months vs summer). You should get a feel after 2-3 draining on how much "stuff" you're collecting though I do wish the can came with a view window.
If the can fills up then only the excess collection after that point will go back through the return hose to the inlet valve port but hopefully with due diligence it should never get to that point.
