Author Topic: MFSW - menu button  (Read 1588 times)
Offline JVS
MFSW - menu button
« on: August 17, 2009, 02:58:11 pm »
The menu button on my MFSW has stopped working. It's a midline computer.
The car was recently in for some air-con work so I asked the technician if there were any fault codes showing in connection with the button failure. He said not.
Anyone else had this problem? Possible suggestions would be greatly appreciated.
TIA
Jim
Offline vRStu
  • -Given: 90
  • -Receive: 159
Re: MFSW - menu button
« Reply #1 on: August 17, 2009, 06:21:41 pm »
Has anyone recently fitted Cruise Control for you?
Stu...
Offline JVS
« Reply #2 on: August 17, 2009, 07:44:20 pm »
It has got cruise but I'm almost certain it was factory fitted.
Offline vRStu
  • -Given: 90
  • -Receive: 159
« Reply #3 on: August 17, 2009, 07:48:18 pm »
It could be that the steering controller coding is wrong.  Seen it a few times as the descriptions can be a little confusing when coding it.
Stu...
Offline JVS
« Reply #4 on: August 17, 2009, 09:04:40 pm »
Thanks Stu.
I'll need to get my local garage with a VCDS for that then.
