Author Topic: DSG box slipping into neutral  (Read 7369 times)
Offline wingnutLP
« on: July 09, 2013, 11:21:47 am »
Hi all,
Three times in the last few days my dsg box has slipped into neutral.
There doesn't seem to be a road speed or throttle input pattern. twice it just went back into D but once I had to stop thankfully in traffic and move it to P and back again.
The most recent time all the gear selector lights on the dash flashed while it was in neutral and until I managed to re engage D. It may have done this the other times but I didn't notice.
Any ideas?
If it happened on the motorway it wouldn't be great fun  :scared:
Offline richtung
  • -Receive: 56
Re: DSG box slipping into neutral
« Reply #1 on: July 09, 2013, 01:54:31 pm »
sounds like the mechtronics unit failing... it was a common occurrence with the MK5 DSG boxes.
Is the car still under warranty by any chance?
Rich
Offline PDT
  • -Receive: 142
« Reply #2 on: July 09, 2013, 02:41:17 pm »
We had an A3 that was doing the exact same thing last week, new Mechatronics unit solved it.
Offline Frodo-anni
  • -Receive: 45
« Reply #3 on: July 09, 2013, 02:57:46 pm »
As above mechatronics unit, had mine changed under extended warranty  :happy2:
mk5 GTI Edition 30 DSG No0391
Offline ConeKiller
« Reply #4 on: July 09, 2013, 03:03:16 pm »
I had this problem, went to VGS and it was the part that selects the gears, not the mechatronics unit thankfully! Was £500ish if i remember correctly
« Reply #5 on: July 09, 2013, 04:21:58 pm »
iirc another member on here had a similar issue that turned out to be the selector mechanism and not the mechatronics unit.
Offline wingnutLP
« Reply #6 on: July 09, 2013, 05:15:13 pm »
no warranty but had a new mecatronics unit under warranty when the car was less than three years old.
How much would a mecatronics unit be?
grr, I could do without this...
Offline Kiwi
« Reply #7 on: July 09, 2013, 09:02:53 pm »
Try a DSG reset via VCDS, you might be surprised :-)
Offline wingnutLP
« Reply #8 on: July 19, 2013, 05:58:33 pm »
Well it has not done it again but if it does I will give it a try.
Thanks for the suggestion.
Offline Frodo-anni
  • -Receive: 45
« Reply #9 on: July 19, 2013, 09:00:58 pm »
I think my VW invoice was in the region of £1,900 for the replacement covered by the warranty.
Offline Ryan88uk
« Reply #10 on: July 25, 2013, 08:14:29 am »
F!!k would a car of say 5-60k miles be worth checking over?
anorganix
« Reply #11 on: July 25, 2013, 08:45:22 am »
Even if your car is not from 2009, I thinks it's worth checking the sensors first. See below. :happy2:
On Aug 2009, VW started a recall on 2009 and 2010 DSG on the temperature sensor. Models affected are built between August and September 2009.
A faulty temperature sensor can result in illuminated warning lamps in the dashboard and the transmission may shift into neutral.
It appears that both sensors below are in the same assembly.
« Last Edit: July 25, 2013, 08:47:06 am by anorganix »
Offline Ryan88uk
« Reply #12 on: July 25, 2013, 09:59:55 am »
Car I'm looking at Saturday is a 2007 is should ok I guess?
Offline n17chm
« Reply #13 on: July 25, 2013, 10:09:43 am »
Can someone explain to me the way they use the DSG gearbox when coming to a stop at traffic lights for instance.
Do you slip it into neutral then back into D or leave it in D with the foot brake on?
« Reply #14 on: July 25, 2013, 10:15:18 am »
Your supposed to place it in neutral just like a conventional box, something to do with the oil temps rising left in D when stationary but i am sure most people dont bother and have not heard of any problems due to this.  :happy2:
