Author Topic: Running wheels 18x9 et 35 and problems  (Read 2089 times)
Offline Ducky76
« on: July 10, 2013, 10:00:19 am »
Hi anybody running 18x9 s don't expect any problems but just wondered if any one is running the same size and were problem free et is 35 I think  cheers andy
Re: Running wheels 18x9 et 35 and problems
« Reply #1 on: July 10, 2013, 11:53:10 am »
ET42-45 is problem free on a 19x8J wheel.
I don't think ET35 will be, but I'm not sure.
Offline JoeDarKa
  • -Given: 57
  • -Receive: 73
« Reply #2 on: July 10, 2013, 12:31:42 pm »
How low are you? Thats the key
Offline Polo6n1600i
« Reply #3 on: July 10, 2013, 03:41:52 pm »
I'm running 8.5x18 et35 with 215/40 - I'm pretty damn low (that's a technical term!) and I'm running stock arches (other than removing the front splash guard bolt) don't see why the extra 1/2 inch would make it any worse - however you'd have to put a but of camber on the back, or just don't run it too low.
Sometimes just touches, but only just.
Offline Ducky76
« Reply #4 on: July 10, 2013, 06:37:53 pm »
Na in not very low on ebach springs there 225 40 on a 9j so could be close lookin at your set up , but like you say then should be ok most of time just with the 40mm drop on gti  :happy2:
Offline JoeDarKa
  • -Given: 57
  • -Receive: 73
« Reply #5 on: July 10, 2013, 06:51:31 pm »
I had no problems 225 on a 9j on lowering springs, rear only. Had 8j on front
Offline Polo6n1600i
« Reply #6 on: July 10, 2013, 07:46:02 pm »
Don't see any issues then
Offline Ducky76
« Reply #7 on: July 10, 2013, 07:50:06 pm »
Sweet then il see on Friday hopefully trial run hopefully if they arrive that is
