Author Topic: RNS510 maps problem  (Read 1233 times)
Offline Nafeun
RNS510 maps problem
« on: July 11, 2013, 03:25:49 pm »
Hello,
I updated the firmware on my new D 510 RNS to the newest modified one which deleted map data.
I then put in the 7920 map DVD and started to install it however I needed the car so stopped it. It now works absolutely fine however I doubt the full disc was installed. Also the speed camera POI are not on the drive. I have attempted to install the maps again however when I inset the map DVD nothing happens. Any idea?
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
Re: Re: RNS510 maps problem
« Reply #1 on: July 11, 2013, 03:26:48 pm »
Have you selected the pois through the setup menu?
Sent From My Samsung S3
Offline Nafeun
« Reply #2 on: July 11, 2013, 04:21:25 pm »
It's not there :(
Offline gruf
« Reply #3 on: July 12, 2013, 10:22:07 am »
Hello,
where can I get a copy.
Thanks :happy2:
Fabreze air fresherner, pink fury dice, reflective door gaurds x4, 1x reflective earth strap, 3 tone horn, heated real leather steering cover, dice dust caps 2x red 2x blue, red gold tissue box on parcel shelf, front windscreen sun strip (GRUF Me JULIE), 4ft steel flexi cb aerial, washed monthly with £shop washing up liquid not to forget parking space 14.5 doors from house.
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
« Reply #4 on: July 12, 2013, 10:36:45 am »
ok, which fw are you on now?
Offline Nafeun
« Reply #5 on: July 12, 2013, 10:49:50 am »
4120 modified for Europe. The poi setting in settings is greyed out. Do I have to manually add then through an sd card even though they have been added to the map data ISO?
As per link, I got it from rnsfirmware.com and maps I can't discuss...
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
« Reply #6 on: July 12, 2013, 11:57:47 am »
Try 3800/3810 modified, I had the same problem when I went to 4120.
Offline Nafeun
« Reply #7 on: July 12, 2013, 01:06:20 pm »
Cheers will do, any links for either firmware? Can't find it on rnsfirmware.com?
