Author Topic: Has my Diverter valve gone again?!!  (Read 521 times)
Offline ajhm
« on: July 12, 2013, 08:28:01 pm »
Hi guys, looking for some advice... Here's a little background to the problem! Basically I bought the car over a year ago and was quite happy with it, wasn't the fastest thing in the world but it was ideal for what I needed. Then I got the urge to have the car mapped but wasn't convinced there was much difference! So after a bit of swatting up on here I decided to replace the Diverter valve with a standard revised replacement bought from awesome, after fitting the valve myself I couldn't believe the difference, easily the best £50 I've spent on a car! This has been fine for a couple of months but after being away working for a couple of weeks I jumped in the car and it seems once again to be a bit "flat" through the revs, so I suppose my question is could the Diverter valve diaphragm have split again after only maybe 2000 miles max?? I know the easiest way to find out is to take off the Diverter and have a look but I'm not going to get that opportunity for a while! Thanks in advance for your help!  :happy2:
Offline Scottymon
  • -Given: 83
  • -Receive: 125
  • UnNaturally Aspirated
Re: Has my Diverter valve gone again?!!
« Reply #1 on: July 12, 2013, 08:31:16 pm »
Do you have VCDS?  You could run a boost requested / boost actual and also see what your roughly putting out BHP/Torque wise.
Offline ajhm
« Reply #2 on: July 12, 2013, 08:34:31 pm »
Afraid not mate, don't have access to VCDS and I stay in the rural highlands of Scotland so a bit of a drive to see any type of specialist! :/
