Author Topic: RNS not working need help from a pro..x  (Read 4711 times)
Offline gruf
« on: July 13, 2013, 06:36:09 pm »
I got the 510 and it worked ok until the battery drained so I updated the can bus and now ive updated the firmware and its sh*t.
I cant use hdd I cant get poi's and the thing is always say...starting up..
can anyone help,
I have firmware 3810, my rns is version c and it now says d after upgrade.
I have downloaded loads of different firmwares but none work. is there a way of downgrading or can someone point me to the right version firmware.
Fabreze air fresherner, pink fury dice, reflective door gaurds x4, 1x reflective earth strap, 3 tone horn, heated real leather steering cover, dice dust caps 2x red 2x blue, red gold tissue box on parcel shelf, front windscreen sun strip (GRUF Me JULIE), 4ft steel flexi cb aerial, washed monthly with £shop washing up liquid not to forget parking space 14.5 doors from house.
Offline GTI-Pirelli
  • -Receive: 27
Re: RNS not working need help from a pro..x
« Reply #1 on: July 13, 2013, 09:39:30 pm »
I am not a pro. This should allow the firmware to be downgraded:
To get to the software downgrade option you will need the "secret menu" enabled on the RNS.
Hold down the "SETUP" button. You will get the following menus:
Standard setup menu. Keep holding...
Radio Service Mode. Keep holding...
Testmode. Let go  :wink:
Select "System" (bottom of the list) and you will get this:
In all honesty I don't know what happens when you press "Enable SW Downgrade", never pressed it before.
Good luck.  :happy2:
2017 Audi S4
Offline StephenED30
  • -Receive: 53
  • Edition 40 No 135
« Reply #2 on: July 13, 2013, 09:53:44 pm »
Recently had the same thing happen to mine, how long did the firmware take too do? Should be about 50 minutes to update. If it was quicker it's not done it correctly. I would suggest the firmware has not taken correctly and requires to be done again, perhaps download from a different site?
Offline gruf
« Reply #3 on: July 13, 2013, 10:07:19 pm »
Good luck.  :happy2:
I cant find the 1100 firmware.
all the links are busted not there anymore
Offline StephenED30
  • -Receive: 53
  • Edition 40 No 135
« Reply #4 on: July 13, 2013, 10:13:53 pm »
Try searching in google, rns firmware.
Offline skard
  • -Receive: 245
« Reply #5 on: July 13, 2013, 10:24:12 pm »
3810 is a version that repartitions your HDD - so you lose all data, including maps, POIs, music.
Think I found a modded 3810a version that worked great on my A unit, also loaded to another members car. Try finding it in my-gti and slowly burn it to a CD then try again?
Edit: the file is called 3810a_noru.rar or click this http://depositfiles.com/files/gbtlf3s2i
« Last Edit: July 13, 2013, 10:30:22 pm by skard »
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
Re: Re: RNS not working need help from a pro..x
« Reply #6 on: July 13, 2013, 10:43:39 pm »
As skard says,  burn at slowest speed. Will have less chances of errors
Sent From My Samsung S3
Offline gruf
« Reply #7 on: July 13, 2013, 10:44:27 pm »
yep I got this fw...this is what started my troubles.
ive managed to downgrade now ans I don't have anything installed now. its just a radio and a nav that keeps asking for map disc.
whats the best option for firmware now...do I go up in stages or go straight for the private dance.
Offline gruf
« Reply #8 on: July 13, 2013, 10:46:11 pm »
im burning at slowest speeds.
if you see my frontroom and car you would crack up. I have disc everywhere
Offline GTI-Pirelli
  • -Receive: 27
« Reply #9 on: July 13, 2013, 11:11:16 pm »
 :worthless:
According to my-gti.com 3810 is the key upgrade as it does the re-partitioning work to go up higher i.e 4020 (not sure what the advantage of 4020 is).
They also say 1100 to 3810 should be fine.
http://www.my-gti.com/3093/volkswagen-rns-510-firmware-upgrade-to-version-3810-3814-3816-3818
http://www.my-gti.com/3354/volkswagen-rns-510-firmware-upgrade-to-version-4020-4024-4026-4028
You could try 2700 then 3810 but personally I would try and limit the number of times you upgrade due to any potential major problems.
2017 Audi S4
Offline gruf
« Reply #10 on: July 14, 2013, 12:46:47 am »
 :worthless:
when you go to download the fw 3810 there are 5 or 6 parts which all have there own links are they all the same do I need all of them or one of them.
I have download a group of files like this earlier and it would only unzip part one and none of the rest.
Offline skard
  • -Receive: 245
« Reply #11 on: July 14, 2013, 08:17:24 am »
I have the 4020 on my A and it's as far as I'll take it, but you need 3810 first to reconfigure the HDD.
You'll need to reload maps from DVD as they'll have been wiped, however cos of the repartitioning from 3810, you'll not lose them in the future.
Might be worth using a laser cleaner on your stereo, that link I put up definitely worked on the cars I did. You'll get there!
Just checking, are you using a CD and not a DVD for firmware? I did.
Offline gruf
« Reply #12 on: July 14, 2013, 08:45:16 am »
I downgraded last night and then installed 3810a nora and it went ok first time...with an old sh*tty blank cd from about 10 years ago.
now that it went on first time and fully with no interruption's or mistakes I know its installed properly. the problem is that my hdd is greyed out and if I use the sd card and go to extras there is no option to copy from sd card, there was before.
can anyone enlighten me on this problem.
Offline gruf
« Reply #13 on: July 15, 2013, 05:29:25 pm »
ive installed fw-4020 without any probs again, cant beat them cheap old disc's..lol
I can get the maps to install, I have 7918 and 7920.
is there any specific map I need for the fw4020.
also the problem is that my hdd is still greyed out and if I use the sd card and go to extras there is no option to copy from sd card, there was before.
Offline skard
  • -Receive: 245
« Reply #14 on: July 15, 2013, 06:17:45 pm »
I believe 7920 maps are same as 7918 but with integrated speed cams, either of those work fine with that firmware.
I think you somehow need to reset your RNS, have you tried holding in the upper buttons? Have you tried a different SD card too?
