Author Topic: RNS not working need help from a pro..x  (Read 4705 times)
Offline gruf
Re: RNS not working need help from a pro..x
« Reply #15 on: July 15, 2013, 06:34:40 pm »
I believe 7920 maps are same as 7918 but with integrated speed cams, either of those work fine with that firmware.
I think you somehow need to reset your RNS, have you tried holding in the upper buttons? Have you tried a different SD card too?
When you say upper buttons do you mean <>+I. if so yep.
I will try different card as well...let you know what happens.
Fabreze air fresherner, pink fury dice, reflective door gaurds x4, 1x reflective earth strap, 3 tone horn, heated real leather steering cover, dice dust caps 2x red 2x blue, red gold tissue box on parcel shelf, front windscreen sun strip (GRUF Me JULIE), 4ft steel flexi cb aerial, washed monthly with £shop washing up liquid not to forget parking space 14.5 doors from house.
Offline skard
  • -Receive: 245
« Reply #16 on: July 15, 2013, 07:04:23 pm »
Had a think...is your SD card quite sizeable? If so check it hasn't been formatted by default in NTFS format, make sure it is FAT or FAT32 so the stereo can see what is on it.
Offline gruf
« Reply #17 on: July 16, 2013, 10:47:49 am »
it can see what's on it coz it plays from it.
the problem is there is no copy to hdd option like I had before I done the update also the dvd don't work either.
I've tried a cd it plays that but when I go to extras there is no copy to hdd function.
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
« Reply #18 on: July 16, 2013, 11:05:51 am »
has the HDD not been greyed out before? Could be a hard drive failure
Offline gruf
« Reply #19 on: July 16, 2013, 12:30:50 pm »
It worked when I had it, it had music on it from the fella I bought it off (not bad as it goes and its all lost)
when I put the sd card in it worked fine and when I went into extras it said copy to hdd.
my poi's are greyed out to.
my dvd don't work and when im on the media screen it only has option for cd where it used to say cd/dvd.
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
« Reply #20 on: July 16, 2013, 01:40:58 pm »
hmm, Im not too sure then. I think if you put in an ordinary CD it will say Cd, it you put dvd in then it says DVD.
Where abouts are you based?
Offline gruf
« Reply #21 on: July 16, 2013, 01:59:19 pm »
[/quote]
Greenwich London
Offline gruf
« Reply #22 on: July 16, 2013, 02:28:40 pm »
I phoned Yarmouth ed and it was a matter of going to SD and picking the album or track and instead of clicking on the track name I had to click the box to the right and then it gave the option of copy.
DON'T I FEEL A RICHARD NOW.
Offline gruf
« Reply #23 on: July 16, 2013, 02:30:07 pm »
Next problem is getting a new map installed.
I can't wait.
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
Re: Re: Re: RNS not working need help from a pro..x
« Reply #24 on: July 16, 2013, 04:49:41 pm »
Lol! Dont worry at least you sorted it now. .
With fw 4020 you might have problems with the 7920 maps showing poi. Thats what happened to me so I went back to 3800.
Im not too far from you (Leyton) so if you have any issues in future you can give me a shout.
Sent From My Samsung S3
Offline gruf
« Reply #25 on: July 16, 2013, 05:28:55 pm »
Topman,
I go past Leyton every Friday and Sunday....get ready to be pestered...
I did try the 7918 and 7920 on the fw3810 but had no joy that's why I kept trying to put fw4020 on for.. looks like it didn't help.
ed said maybe its the disc im using.
bugjam at the weekend,
I think I might go up on the ponce and harass some V dubbers for a quick go of a original map..i bet one of them has one in the boot or there cd collection..lol
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
« Reply #26 on: July 16, 2013, 07:49:45 pm »
Ditch the 3810 noru, try just 3800.
Offline biglad65
« Reply #27 on: September 22, 2013, 08:16:56 pm »
it lets you downgrade to a lower number thats in your sat nav i did it with video in motion
