November 20, 2024, 03:17:58 pm
All Things Mk5
Mk5 General Area
How often does the AC need re gassed !
Topic: How often does the AC need re gassed ! (Read 1293 times)
gobbleplease
Just look at my post count
-Given: 64
-Receive: 48
July 13, 2013, 07:15:45 pm »
I was wondering how often you guys usually need to re gas your AC, mines is blowing hot air at the moment
Also how much does it cost from vw roughly ?
MK7 GTI - ARRIVING DECEMBER
sanj
Won't Shut up.
-Given: 17
-Receive: 26
Re: How often does the AC need re gassed !
Reply #1 on:
July 13, 2013, 07:25:56 pm »
Around £50 at most car place's such as Kwikfit as i'm sure VW might be double that,mine need's doing too!
skard
-Given: 5
-Receive: 245
My Ride:
Reply #2 on:
July 13, 2013, 07:35:05 pm »
Find an aircon specialist, you'll find they are cheaper than KwikFit types and will actually do a proper service/vacuum.
I got mine done recently at a local VAG specialist, it was £40.
Gazza747
Always Involved
-Given: 15
-Receive: 16
Reply #3 on:
July 13, 2013, 09:14:55 pm »
Air con service recommended once every 2 years
2013 Golf mk7 1.4 tsi SE DSG
2011 Golf mk6 2.0 tdi Match manual (sold)
2007 Golf mk5 GTi manual (sold)
Mk5Dom
Always Involved
-Given: 3
-Receive: 19
Reply #4 on:
July 13, 2013, 09:21:03 pm »
Dealers charge 29.00 for an air con refresh and 79.00 for an air con service.
Kwik fit lulz.
doylebros
-Given: 44
-Receive: 309
Reply #5 on:
July 13, 2013, 09:24:55 pm »
What's the difference between service and recharge?
sanj
Won't Shut up.
-Given: 17
-Receive: 26
Reply #6 on:
July 13, 2013, 09:25:16 pm »
Quote from: Mk5Dom on July 13, 2013, 09:21:03 pm
Kwik fit lulz.
Ok I get your point!
torque777
Won't Shut up.
-Given: 0
-Receive: 12
Re: Re: How often does the AC need re gassed !
Reply #7 on:
July 13, 2013, 10:06:41 pm »
Basically refresh is an aircon bomb inside and a service is a check of gas in system ..tends to be topped up ...if your lucky they will recover complete ..vac it down and then recharge it with a mixture of your old gas and there new gas ...with a sqiurt of pag 100 oil and jobs a good un ...I find every 3-4 years is worth a check ...sooner if you very rarely use aircon as oil will settle in lowest part of system and seals will go dry and leak
sent using my own fingers
doylebros
-Given: 44
-Receive: 309
Reply #8 on:
July 13, 2013, 10:10:27 pm »
Thought all aircon systems automatically worked even when off, for the issue you mentioned (oil seals) just at low percentage value?
torque777
Won't Shut up.
-Given: 0
-Receive: 12
Reply #9 on:
July 14, 2013, 06:50:22 am »
The problem is all systems leak ...I'm only talking of a very small amount thats why after a few years the system needs a top up ....if they built the system like your house hold fridge it would remain sealed for years lol
gobbleplease
-Given: 64
-Receive: 48
Reply #10 on:
July 14, 2013, 09:22:54 am »
Cool air con re gas and service it's Is and ill enquire about what what this entails eg if I get the lube oil squirt and vac !
Mines deffo needs done Ive got every recipt from new and no air con work has been carried out so its service time.
Andy
Admin
-Given: 39
-Receive: 443
Reply #11 on:
July 14, 2013, 10:25:06 am »
Had mine done at work on fri wish was great in the lovely weather we are having
gttdi build thread
r32 build thread
All Things Mk5
Mk5 General Area
