Author Topic: Possible PCV failing?  (Read 814 times)
Offline Craigh1983
    • Leicester Wedding Photographers
« on: July 13, 2013, 07:33:52 pm »
Hi guys,
Have a stage 1 remap and recently had a new turbo and dv valve change. Car pulled like a train. Recently I have noticed it doesn't seem to pull as much when I put my foot down.
So I thought I'd try taking out the oil dip stick to see if the car would hunt. When first taking it out the engine grunted slightly and then very slightly started to rev a little faster but it didn't really start to chug a lot like I remember it doing before.
Could this be a sign that the pcv has had it?
Craigh
Saintsteve
Re: Possible PCV failing?
« Reply #1 on: July 13, 2013, 08:39:03 pm »
Remove your engine cover and try a blow back test to see if the valve leaks?. I would check that before parting with your 35 hard earned.
Offline Craigh1983
« Reply #2 on: July 13, 2013, 08:47:44 pm »
Hi Steve,
Err sorry how do I do a blue back test? :)
Saintsteve
« Reply #3 on: July 13, 2013, 09:04:21 pm »
Quote from: Craigh1983 link=topic=69469.msg752607#msg752607date=1373744864
Hi Steve,
Take the main plastic hose off, and try blow/sucking  :signLOL:
 :wink:
Offline Craigh1983
« Reply #4 on: July 13, 2013, 09:09:47 pm »
Errrrrr ok.... Lol
What will I be looking for when I'm blowing and sucking? Lol
Saintsteve
« Reply #5 on: July 13, 2013, 09:13:20 pm »
You will feel a ball valve feeling which only should allow air flow In one direction.If you don't, then it's duff  :smiley:
Offline Craigh1983
« Reply #6 on: July 13, 2013, 09:15:11 pm »
Ahhh I will give that a try tomorrow :)
Cheers Steve!
Offline Craigh1983
« Reply #7 on: July 13, 2013, 09:25:24 pm »
One more thing. Do I do that with the engine running or turned off?
Saintsteve
« Reply #8 on: July 13, 2013, 09:36:57 pm »
Turned off...   Could be interesting if you did with it on though..
You might get a whiff of oil vapour when you check it ok, so have the mouthwash to hand  :laugh:
